Can't run configuration
- PeteJM
05 Jan 2020 20:27 #154106
by PeteJM
Can't run configuration was created by PeteJM
Hi all,
I have built a configuration using the 7i96 config tool but when i open linuxcnc and try to run the config, it won't open and i get an error file. I have attached the file report.
How can i get it to run?
Thanks in advance.
Thanks in advance.
- Thank you received: 5321
05 Jan 2020 20:40 #154108
Replied by PCW on topic Can't run configuration
Do you need PWM?
- PeteJM
05 Jan 2020 20:51 #154109
by PeteJM
Replied by PeteJM on topic Can't run configuration
No
05 Jan 2020 20:54 #154110
Is it possible you selected some option that uses PWM (say spindle speed control) when running the configuration utility?
If not, its a configuration utility bug (you should be able to get running by editing the hal file and deleting any lines that reference "pwmgen")
The following user(s) said Thank You: PeteJM
Time to create page: 0.078 seconds
