Spindle output not working on 7i76 SOLVED (my Bad)
- bevins
- Thank you received: 338
09 Jan 2020 13:14 - 09 Jan 2020 16:15 #154435
by bevins
Spindle output not working on 7i76 SOLVED (my Bad) was created by bevins
I have been configuring spindle delays and spindle stopped working. I cannot get spindle to turn on, actually output of 7i786. I dont know if I blew it up or what but I cannot get spindle to turn on anymore.
Can someone have a look at hal file?
Warning: Spoiler!
# Generated by PNCconf at Wed Dec 4 06:18:45 2019
# Using LinuxCNC version: UNAVAILABLE
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=1 num_pwmgens=0 num_stepgens=4 sserial_port_0=200xxx"
setp hm2_7i92.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.x2,pid.y,pid.z,pid.s
loadrt mux4 count=3
addf hm2_7i92.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.x2.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i92.0.write servo-thread
addf mux4.0 servo-thread
setp hm2_7i92.0.dpll.01.timer-us -50
setp hm2_7i92.0.stepgen.timer-number 1
# external output signals
# external input signals
# --- BOTH-HOME-X ---
net both-home-x <= hm2_7i92.0.7i76.0.0.input-01
# --- BOTH-HOME-X2 ---
net both-home-x2 <= hm2_7i92.0.7i76.0.0.input-02
# --- BOTH-HOME-Y ---
net both-home-y <= hm2_7i92.0.7i76.0.0.input-03
# --- BOTH-HOME-Z ---
net both-home-z <= hm2_7i92.0.7i76.0.0.input-04
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .01
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# Step Gen signals/setup
setp hm2_7i92.0.stepgen.00.dirsetup [JOINT_0]DIRSETUP
setp hm2_7i92.0.stepgen.00.dirhold [JOINT_0]DIRHOLD
setp hm2_7i92.0.stepgen.00.steplen [JOINT_0]STEPLEN
setp hm2_7i92.0.stepgen.00.stepspace [JOINT_0]STEPSPACE
setp hm2_7i92.0.stepgen.00.position-scale [JOINT_0]STEP_SCALE
setp hm2_7i92.0.stepgen.00.step_type 0
setp hm2_7i92.0.stepgen.00.control-type 1
setp hm2_7i92.0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output <= hm2_7i92.0.stepgen.00.velocity-cmd
net x-pos-fb <= hm2_7i92.0.stepgen.00.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => hm2_7i92.0.stepgen.00.enable
# ---setup home / limit switch signals---
net both-home-x => joint.0.home-sw-in
net both-home-x => joint.0.neg-lim-sw-in
net both-home-x => joint.0.pos-lim-sw-in
# Tandem AXIS X2 JOINT 1
setp pid.x2.Pgain [JOINT_1]P
setp pid.x2.Igain [JOINT_1]I
setp pid.x2.Dgain [JOINT_1]D
setp pid.x2.bias [JOINT_1]BIAS
setp pid.x2.FF0 [JOINT_1]FF0
setp pid.x2.FF1 [JOINT_1]FF1
setp pid.x2.FF2 [JOINT_1]FF2
setp pid.x2.deadband [JOINT_1]DEADBAND
setp pid.x2.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.x2.error-previous-target true
setp pid.x2.maxerror .01
net x2-index-enable <=> pid.x2.index-enable
net x2-enable => pid.x2.enable
net x2-pos-cmd => pid.x2.command
net x2-pos-fb => pid.x2.feedback
net x2-output <= pid.x2.output
# Step Gen signals/setup for tandem axis
setp hm2_7i92.0.stepgen.01.dirsetup [JOINT_1]DIRSETUP
setp hm2_7i92.0.stepgen.01.dirhold [JOINT_1]DIRHOLD
setp hm2_7i92.0.stepgen.01.steplen [JOINT_1]STEPLEN
setp hm2_7i92.0.stepgen.01.stepspace [JOINT_1]STEPSPACE
setp hm2_7i92.0.stepgen.01.position-scale [JOINT_1]STEP_SCALE
setp hm2_7i92.0.stepgen.01.step_type 0
setp hm2_7i92.0.stepgen.01.control-type 1
setp hm2_7i92.0.stepgen.01.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.01.maxvel [JOINT_1]STEPGEN_MAXVEL
net x2-pos-cmd <= joint.1.motor-pos-cmd
net x2-vel-cmd <= joint.1.vel-cmd
net x2-output <= hm2_7i92.0.stepgen.01.velocity-cmd
net x2-pos-fb <= hm2_7i92.0.stepgen.01.position-fb
net x2-pos-fb => joint.1.motor-pos-fb
net x2-enable <= joint.1.amp-enable-out
net x2-enable => hm2_7i92.0.stepgen.01.enable
net both-home-x2 => joint.1.home-sw-in
net both-home-x2 => joint.1.neg-lim-sw-in
net both-home-x2 => joint.1.pos-lim-sw-in
# AXIS Y JOINT 2
setp pid.y.Pgain [JOINT_2]P
setp pid.y.Igain [JOINT_2]I
setp pid.y.Dgain [JOINT_2]D
setp pid.y.bias [JOINT_2]BIAS
setp pid.y.FF0 [JOINT_2]FF0
setp pid.y.FF1 [JOINT_2]FF1
setp pid.y.FF2 [JOINT_2]FF2
setp pid.y.deadband [JOINT_2]DEADBAND
setp pid.y.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror .01
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-pos-fb => pid.y.feedback
net y-output <= pid.y.output
setp hm2_7i92.0.stepgen.02.dirsetup [JOINT_2]DIRSETUP
setp hm2_7i92.0.stepgen.02.dirhold [JOINT_2]DIRHOLD
setp hm2_7i92.0.stepgen.02.steplen [JOINT_2]STEPLEN
setp hm2_7i92.0.stepgen.02.stepspace [JOINT_2]STEPSPACE
setp hm2_7i92.0.stepgen.02.position-scale [JOINT_2]STEP_SCALE
setp hm2_7i92.0.stepgen.02.step_type 0
setp hm2_7i92.0.stepgen.02.control-type 1
setp hm2_7i92.0.stepgen.02.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.02.maxvel [JOINT_2]STEPGEN_MAXVEL
net y-pos-cmd <= joint.2.motor-pos-cmd
net y-vel-cmd <= joint.2.vel-cmd
net y-output <= hm2_7i92.0.stepgen.02.velocity-cmd
net y-pos-fb <= hm2_7i92.0.stepgen.02.position-fb
net y-pos-fb => joint.2.motor-pos-fb
net y-enable <= joint.2.amp-enable-out
net y-enable => hm2_7i92.0.stepgen.02.enable
net both-home-y => joint.2.home-sw-in
net both-home-y => joint.2.neg-lim-sw-in
net both-home-y => joint.2.pos-lim-sw-in
# AXIS Z JOINT 3
setp pid.z.Pgain [JOINT_3]P
setp pid.z.Igain [JOINT_3]I
setp pid.z.Dgain [JOINT_3]D
setp pid.z.bias [JOINT_3]BIAS
setp pid.z.FF0 [JOINT_3]FF0
setp pid.z.FF1 [JOINT_3]FF1
setp pid.z.FF2 [JOINT_3]FF2
setp pid.z.deadband [JOINT_3]DEADBAND
setp pid.z.maxoutput [JOINT_3]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .01
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
setp hm2_7i92.0.stepgen.03.dirsetup [JOINT_3]DIRSETUP
setp hm2_7i92.0.stepgen.03.dirhold [JOINT_3]DIRHOLD
setp hm2_7i92.0.stepgen.03.steplen [JOINT_3]STEPLEN
setp hm2_7i92.0.stepgen.03.stepspace [JOINT_3]STEPSPACE
setp hm2_7i92.0.stepgen.03.position-scale [JOINT_3]STEP_SCALE
setp hm2_7i92.0.stepgen.03.step_type 0
setp hm2_7i92.0.stepgen.03.control-type 1
setp hm2_7i92.0.stepgen.03.maxaccel [JOINT_3]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.03.maxvel [JOINT_3]STEPGEN_MAXVEL
net z-pos-cmd <= joint.3.motor-pos-cmd
net z-vel-cmd <= joint.3.vel-cmd
net z-output <= hm2_7i92.0.stepgen.03.velocity-cmd
net z-pos-fb <= hm2_7i92.0.stepgen.03.position-fb
net z-pos-fb => joint.3.motor-pos-fb
net z-enable <= joint.3.amp-enable-out
net z-enable => hm2_7i92.0.stepgen.03.enable
net both-home-z => joint.3.home-sw-in
net both-home-z => joint.3.neg-lim-sw-in
net both-home-z => joint.3.pos-lim-sw-in
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-on <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
#net coolant-mist <= iocontrol.0.coolant-mist
#net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
#net estop-out <= iocontrol.0.user-enable-out
#net estop-out => iocontrol.0.emc-enable-in
loadrt estop_latch
addf estop-latch.0 servo-thread
net estop-loopout iocontrol.0.emc-enable-in <= estop-latch.0.ok-out
net estop-loopin iocontrol.0.user-enable-out => estop-latch.0.ok-in
net estop-reset iocontrol.0.user-request-enable => estop-latch.0.reset
net remote-estop estop-latch.0.fault-in <= hm2_7i92.0.7i76.0.0.input-00-not
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
Last edit: 09 Jan 2020 16:15 by bevins.
- bevins
09 Jan 2020 13:17 - 09 Jan 2020 13:19 #154436
by bevins
Replied by bevins on topic Spindle output not working on 7i76
mdi commands not working either. M3 S12000
Is it possible to blow the output changing hal signals etc? Connecting output to something it is not suppose to be?
Last edit: 09 Jan 2020 13:19 by bevins.
- Thank you received: 7468
09 Jan 2020 15:21 #154448
Replied by tommylight on topic Spindle output not working on 7i76
No, not that i can think of despite a great stretch of imagination.Is it possible to blow the output changing hal signals etc? Connecting output to something it is not suppose to be?
- Thank you received: 5321
09 Jan 2020 20:33 #154486
Replied by PCW on topic Spindle output not working on 7i76
There doesn't seem to be any hal connection from the spindle-on signal to any 7I76 output.
At the minimum, if you are using the 7I76's analog spindle interface you
would expect
hm2_7i92.0.7i76.0.0.spindir
hm2_7i92.0.7i76.0.0.spinena
hm2_7i92.0.7i76.0.0.spinout
to be connected
would expect
to be connected
Time to create page: 0.398 seconds
