GCode and XXYZ machine vs XYZ
  • ross_dev
  • Topic Author
  • Senior Member
  • Senior Member
6 years 9 months ago #154536 by ross_dev
GCode and XXYZ machine vs XYZ was created by ross_dev
Hello
I have been exporting gcode from a popular CAM package in order to test the first three stages of our machine. It is modeled in vismach as XYZ only and the gcode works well.
The real machine is XXYZ, do you know if any modification needs to be made to the gcode or the way the CAM exports it to take account of the additional X, or will LCNC just pass the commands to both x assuming a correctly configured ini?
Cheers and happy new year (belated!)
  • Moderator
  • Moderator
6 years 9 months ago #154571 by tommylight
Replied by tommylight on topic GCode and XXYZ machine vs XYZ
ross_dev wrote: The real machine is XXYZ, do you know if any modification needs to be made to the gcode or the way the CAM exports it to take account of the additional X, or will LCNC just pass the commands to both x assuming a correctly configured ini?
No and yes.
The following user(s) said Thank You: ross_dev
6 years 9 months ago #154599 by rodw
Replied by rodw on topic GCode and XXYZ machine vs XYZ
You only have one X axis. The XXYZ string in your ini file is telling Linuxcnc which JOINTS (motors) make up your X AXIS.
So at a G code level, you only have a 3 Axis XYZ machine.
  • ross_dev
  • Topic Author
  • Senior Member
  • Senior Member
6 years 9 months ago #154745 by ross_dev
Replied by ross_dev on topic GCode and XXYZ machine vs XYZ
That's great thanks! Much obliged gents
Time to create page: 0.045 seconds
