- LinuxCNC
- General LinuxCNC Questions
- How to add home all button to axis GUI. I don't use homing switches.
- freddie
11 Jan 2020 22:36 #154646
by freddie
How to add home all button to axis GUI. I don't use homing switches. was created by freddie
Is there a simple way to add a home all button to axis gui if you don't have homing switches?
- BigJohnT
- Thank you received: 994
11 Jan 2020 23:31 - 11 Jan 2020 23:32 #154653
by BigJohnT
Replied by BigJohnT on topic How to add home all button to axis GUI. I don't use homing switches.
You must set a home sequence in the ini file for all axes then the home all button shows up. You also must set the home search velocity to 0 for all axes to set the current location as home.
linuxcnc.org/docs/2.7/html/config/ini-co...s__lt_num_gt_section
JT
JT
Last edit: 11 Jan 2020 23:32 by BigJohnT.
- freddie
12 Jan 2020 03:35 #154661
by freddie
Replied by freddie on topic How to add home all button to axis GUI. I don't use homing switches.
Thanks, I got it working. I had to go to stepconfig and setup pins for home switches as if I had them and then the homing showed up in the ini file. I changed velocity to 0 and also set latch velocity to 0. The home all button showed up and works great!
- LinuxCNC
Time to create page: 0.688 seconds
