E-Stop
- curtisa
- Thank you received: 15
20 Jan 2020 09:24 #155237
by curtisa
Replied by curtisa on topic E-Stop
If all you want is the external E-stop switch to enable/disable the charge pump function (and also trigger the software E-stop button in Axis to halt things), you can simplify your 'E-stop Test' HAL config a bit.
Near the top of 'E-stop Test', delete the following two lines:
Change the parallel port pin 17 net definition from:
To:
Near the bottom of the HAL file change the following two lines:
To:
Modifying things so that both your physical E-stop and the software E-stop in Axis run in tandem is a bit more messy. I personally don't bother with a software E-stop and prefer the hardware one, as it takes longer for me to find the right key on the keyboard than it does for me to hit a big red button when things start going wrong.
net estop-out charge-pump.enable iocontrol.0.user-enable-out
net charge-pump <= charge-pump.outChange the parallel port pin 17 net definition from:
net charge-pump => parport.0.pin-17-outTo:
net charge-pump.out => parport.0.pin-17-outNear the bottom of the HAL file change the following two lines:
net estop-ext => iocontrol.0.emc-enable-inTo:
net estop-ext => charge-pump.enable
net estop-ext => iocontrol.0.emc-enable-inModifying things so that both your physical E-stop and the software E-stop in Axis run in tandem is a bit more messy. I personally don't bother with a software E-stop and prefer the hardware one, as it takes longer for me to find the right key on the keyboard than it does for me to hit a big red button when things start going wrong.
- jhavanki
20 Jan 2020 21:30 - 20 Jan 2020 21:33 #155276
by jhavanki
Replied by jhavanki on topic E-Stop
Thank you for the reply.
I changed to HAL as you specified above and get the following debug error when EMC2 loads:
Debug file information:
./E-Stop_Test.hal:41: Signal name 'charge-pump.out' must not be the same as a pin. Did you omit the signal name?
4011
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Here is the HAL file.....:
# Generated by stepconf 1.1 at Sat Jan 18 14:17:44 2020
# overwritten when you run stepconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hal_parport cfg="0Xc800 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0
loadrt charge_pump
# net estop-out charge-pump.enable iocontrol.0.user-enable-out
# net charge-pump <= charge-pump.out
addf charge-pump base-thread
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm <= motion.spindle-speed-out
net spindle-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-cmd-rps <= motion.spindle-speed-out-rps
net spindle-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-at-speed => motion.spindle-at-speed
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
# net charge-pump => parport.0.pin-17-out
net estop-ext <= parport.0.pin-10-in
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
# net estop-out <= iocontrol.0.user-enable-out
# net estop-ext => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
4011
loadrt trivkins
loadrt charge_pump
Last edit: 20 Jan 2020 21:33 by jhavanki.
- curtisa
20 Jan 2020 23:13 #155283
by curtisa
Odd, I would've thought that was a valid net expression. Try restoring the following line back in near the top:
And restoring parallel port pin 17:
net charge-pump <= charge-pump.outAnd restoring parallel port pin 17:
net charge-pump => parport.0.pin-17-outPlease Log in or Create an account to join the conversation.
- Thank you received: 5316
20 Jan 2020 23:31 #155285
Replied by PCW on topic E-Stop
The first token after the net command must be a signal, not a pin
( charge-pump.out is a pin )
The following user(s) said Thank You: curtisa
Time to create page: 0.103 seconds
