Homing a PID
- bbsr_5a
- Thank you received: 106
21 Jan 2020 16:10 #155332
by bbsr_5a
Homing a PID was created by bbsr_5a
Hi
i got a rackATC and it workes great on V axis setup STEPPER via 7i92Mesa
i want to go for a different Kinetics xyzac (switchKinetics)
Therefor i look to get rid of the V comand lines and use a PID
Q: I can not find a Guide on how to Setup a PID without Axis/Join relation and HOME that on the default Startup
the Pid needs to act as a Joint/Axis Command Pos
DOES THIS work Eighter or do i need to trweek the kinetics to leave V untouched
The Racktoolchanger acts on POS command only via M6 remap ngc
i did see a Carusell Comp but this needs switches per pocket or detect pocket movement i guess so 2 more inputs
(pocket,index at min i guess want to avoid this
Please HELP
Please HELP
- Thank you received: 4652
22 Jan 2020 16:01 #155432
Replied by andypugh on topic Homing a PID
What is the feedback from your carousel? (ie, exactly what pins do you have?)
You can't really home a PID, but you can zero an encoder on index reasonably easily, and that might work.
- bbsr_5a
22 Jan 2020 18:43 #155444
by bbsr_5a
Replied by bbsr_5a on topic Homing a PID
First Thank you for Answering
I think i am approaching the Wrong way
it is a Stepper with a GT2 belt that drives a linier "Axis! that hold tools
there is the Stepper and the Inductive Switch all 6 Inductive switches of the Machine Fire the Same Pin
it workes on V Axis but only on Trivial Kinetics and if i Change to %axis kinetics the Problems Start
SO my Guess and best Advice be take the ATC away from the Joint Coordinates
to a Stand-alone commanded Thing
but as my English is far from Perfect i'am Stuck in search
Carousel may not be best for Racktoolchanger
is there something else in the HAL components that woudt fit
Requierment is to move the Stepper on Command per pocket number and ToolDistoffset at the ATC rack
in Remap NGC POS ATC = toolnr *dist
24 Jan 2020 11:39 #155641
If the tools move, then it sounds like a carousel.
Is there any chance at all of adding a second channel for individual tool positions?
There might be a way to distinguish different _lengths_ of inductive switch targets.
Time to create page: 0.172 seconds
