New Modern System
- electrosteam
- Thank you received: 8
22 Jan 2020 10:40 #155419
by electrosteam
New Modern System was created by electrosteam
A friend has acquired a 1990's industrial router without any documentation that seems functional.
It is very robust, about 600 x 400 mm, has DOS 6.2, a floppy drive and a Hp style plotter language files operating on bespoke hardware.
Steppers are about size 17 (from memory of a cursory glance).
We have not yet got it to do an actual job, but I have confidence we will.
We are starting to speculate on how we will upgrade it.
I have seen numerous threads discussing various aspects of a 'modern' system.
The budget is moderately flexible and we have no hardware on hand.
I have LCNC operating on a desktop through a BOB to Leadshine drivers to a turret mill.
So, my thoughts turn to LCNC, but on current hardware.
Could one of our members please describe for us a minimal system.
For instance, is a Raspberry Pi with Mesa ethernet cards the 'best' way.
Are there any tutorials on how to put a new system together ?
Thanks in advance,
John.
Thanks in advance,
John.
- bbsr_5a
- Thank you received: 106
22 Jan 2020 12:46 #155423
by bbsr_5a
Replied by bbsr_5a on topic New Modern System
the main Question shoudt be what are you willing to invest into
use a MINIPC and mesa that is a real good start
Use 57 steppers Nema23 at that Mashine Size
use 48V Power
if you got MONEY use Hybrid system 2Nm
use 48V Power
- Thank you received: 7468
22 Jan 2020 16:30 #155433
Replied by tommylight on topic New Modern System
From an old PC with a parallel port that can be found for 30 to 100$ and up to a new PC with Mesa ethernet boards, there are plenty of options.
First check what drives the machine uses.
BTW, i have never seen anything industrial with Nema17 motors, although i have seen and fixed a 5 axis CNC with a 60000RPM spindle that had Nema17 motors !
- Thank you received: 4652
26 Jan 2020 20:56 #155849
LinuxCNC can run on a Pi, but I wou;t describe it as optimal.
The lest-trouble is probably still a Mini-ITX PC with a PCI or PCIe port or the parallel port.
But Ethernet to a Mesa card is starting to look like a more future-proof setup.
Replied by andypugh on topic New Modern System
- electrosteam
29 Jan 2020 07:38 #156072
by electrosteam
Replied by electrosteam on topic New Modern System
My mate has decided to acquire an Arduino system through Bangood, could be less than AUD 25.
This will be interesting !
Thanks for all the good advice, none of it is lost on me,
- BeagleBrainz
- Visitor
29 Jan 2020 08:54 #156075
by BeagleBrainz
Replied by BeagleBrainz on topic New Modern System
He'll soon finding the short comings of an Arduino (grbl) system.
Plus I'd be a bit worried about anything from china at the moment, dunno what "extras" you'd be bringing back home........might be worth soaking it in a few litres of Bundy Rum.
I'd rather use HPGL rather than grbl hahahaha
29 Jan 2020 12:39 #156085
I've been getting a constant stream of some small voltage regulators from China lately, so far they just regulate the voltage, if by any chance they start regulating my body temperature instead, will be sure to report.
LOL
The following user(s) said Thank You: BeagleBrainz
Time to create page: 0.282 seconds
