Linux Newb
- Thank you received: 7468
25 Jan 2020 19:48 #155749
MAX_LINEAR_VELOCITY is the maximum speed the Machine can travel, meaning the combination of speeds of 2 or more axis moving at the same time, example:
When jogging or moving X and Y at the same time, the head is moving diagonally at a faster speed than any one of it's axis.
SCALE should be the steps needed to move an axis 1 inch, so the motor does 200 steps per rotation, if that motor is directly mounted to a ball screw with a pitch of 5mm, that gives us 40 steps per mm. You will have to also factor in microstepping and/or reduction, or belt teeth on the driving pulley, or the rack/pinion pitch. Sorry i can not be more helpful about this but i never use calculators or any kind of help with the scale as i calculate all in my head very quickly, or when i have unknowns i just enter something and then use the Calibration menu to do the fine tuning.
Replied by tommylight on topic Linux Newb
Yes and yes.So if I want to increase my top end feed rate and cutting speed I would just increase max_velocity right? Guessing Axis 0 is X, 1 is Y and 2 is Z?
- stubb21
25 Jan 2020 21:52 #155759
by stubb21
Replied by stubb21 on topic Linux Newb
Gotcha thank you! Well I think for what I need I will just increase the max_velocity gradually and find a good sweet spot. What you are talking about seems like more than I need/understand lol. I Greatly appreciate your help!
- stubb21
27 Jan 2020 22:40 #155964
by stubb21
Updated Max velocity and found a good speed, thank you.
How do setup a touch plate for Joe?
28 Jan 2020 16:30 #156015
Who is Joe ?
You are welcomed, always. Thank you for reporting back.Updated Max velocity and found a good speed, thank you.
Who is Joe ?
- stubb21
28 Jan 2020 23:22 #156054
by stubb21
The program. Maybe the previous feller named it Joe lol. But LinuxCNC lol
- stubb21
31 Jan 2020 03:03 #156230
by stubb21
Thoughts on the touch plate setup?
- Thank you received: 4652
11 Feb 2020 13:07 #157044
Do you have a spare input on the parallel port? (Assuming you are using the parallel port)
Replied by andypugh on topic Linux Newb
Time to create page: 0.094 seconds
