Removing "Run Anyway" message and button in the dialogue?
- ytiuqibu
- Thank you received: 3
27 Jan 2020 12:05 #155894
by ytiuqibu
Removing "Run Anyway" message and button in the dialogue? was created by ytiuqibu
Is it possible to remove the "run Anyway" message and button from the dialogue that appears when a file will exceed soft limits?
We are still trying to track down some intermittent joint error causes on X and Z (Y axis is happy with pin set to Both Limits + Home) so in order to have the machine running we have set X and Z to Home only. As a result we will be relying on soft limits in our working config and would rather have users forced to abandon their job if they exceed design parameters (we can use a separate config for those jobs that require pass through or tiling of work pieces).
- bbsr_5a
- Thank you received: 106
27 Jan 2020 15:44 #155920
by bbsr_5a
Replied by bbsr_5a on topic Removing "Run Anyway" message and button in the dialogue?
USE HOME Ref alone untill it runs your way
and dont Forget
HOME_Offset is the SWITCH Position
HOME is the Location the Machine DRIVES to
SO BOTH needs to be Different as Special on More Switches to one PIN
i got all 9Switches on one PIN and it workes great
if you POST your INI the Users here can look at it and Correct the Faults
it is a understanding problem as most are not the English native Thinkers as me also
and dont Forget
- ytiuqibu
28 Jan 2020 06:32 #155978
by ytiuqibu
Replied by ytiuqibu on topic Removing "Run Anyway" message and button in the dialogue?
Thank you I understand the switches fairly well now.
I just need to know how to change the message dialogue box that pops up when a job is outside the limits I have set.
- bbsr_5a
28 Jan 2020 10:46 #155985
by bbsr_5a
this is for safty
if you want to have no messages set your box to a greater value for testing
and ofcause you can delete the VAR and var.bak file so the setup doesent know were you have been
- ytiuqibu
28 Jan 2020 11:15 #155992
by ytiuqibu
Yes thank you I understand that too - I don't want to stop the message from appearing I just want to have only one option - that is "Close" so users will come and ask me why they can't run their jobs.
We are a Men's Shed with 90 members and a shared CNC (and other machinery) I can tell them not to click the "Run Anyway" button if the message appears but I would prefer if that button option was not available. In fact it would be good if I could change the words in the message to say "see the supervisor".
Thanks again anyway.
- Thank you received: 2175
28 Jan 2020 13:56 #156009
Replied by cmorley on topic Removing "Run Anyway" message and button in the dialogue?
You would need to modify AXIS - this is not configurable otherwise.
Chris
Chris
- bbsr_5a
28 Jan 2020 14:28 #156011
by bbsr_5a
as far as i know THE machine will not run Anyway if there is a Gcode error
did you try to run a G-code that is out of software limits
i just checkt on Plasma and on mill it wont run on my machines in any cases if there is a Limit out of Bounce
- phillc54
- Thank you received: 2100
29 Jan 2020 02:12 #156061
by phillc54
Replied by phillc54 on topic Removing "Run Anyway" message and button in the dialogue?
You can add this code to your ~/.axisrc file, it will run instead of the same named function in Axis.The only change to the original is:was:This change makes only one button and returns 1 so it will always cancel the run command.
If you don't have ~/.axisrc you can create a new one. Be aware that ~/.axisrc applies to all LinuxCNC configs, if you want it for a specific config you need a USER_COMMAND_FILE set in the .ini file for that config.
linuxcnc.org/docs/devel/html/gui/axis.html#_axisrc
linuxcnc.org/docs/devel/html/gui/axis.html#_user_command_file
Tested on LinuxCNC 2.9 but should work on 2.7 & 2.8
def run_warn():
warnings = []
if o.canon:
machine_limit_min, machine_limit_max = soft_limits()
for i in range(3): # Does not enforce angle limits
if not(s.axis_mask & (1<<i)): continue
if o.canon.min_extents_notool[i] < machine_limit_min[i]:
warnings.append(_("Program exceeds machine minimum on axis %s")
% "XYZABCUVW"[i])
if o.canon.max_extents_notool[i] > machine_limit_max[i]:
warnings.append(_("Program exceeds machine maximum on axis %s")
% "XYZABCUVW"[i])
if warnings:
text = "\n".join(warnings)
return int(root_window.tk.call("nf_dialog", ".error",
_("Program exceeds machine limits"),
text,
"warning",
0, _("Please see the supervisor"),)) + 1
return 0 0, _("Please see the supervisor"),)) + 1 1, _("Run Anyway"), _("Cancel")))If you don't have ~/.axisrc you can create a new one. Be aware that ~/.axisrc applies to all LinuxCNC configs, if you want it for a specific config you need a USER_COMMAND_FILE set in the .ini file for that config.
- ytiuqibu
29 Jan 2020 08:08 #156073
by ytiuqibu
Thanks very much Phil - this will give what we need!
- Thank you received: 4652
06 Feb 2020 15:16 - 06 Feb 2020 15:16 #156639
The dialog is here:
github.com/LinuxCNC/linuxcnc/blob/a7eaec...cripts/axis.py#L1801
I think you would need to change the dialog to always return true (looking at where it is used)
Maybe
Replied by andypugh on topic Removing "Run Anyway" message and button in the dialogue?
The dialog is here:
Maybe
if warnings:
dummy = int(root_window.tk.call("nf_dialog", ".error",
text,
"warning",
return 1
Last edit: 06 Feb 2020 15:16 by andypugh.
