REMAP function doesn't work
- aleksamc
- Thank you received: 67
27 Jan 2020 20:17 #155946
by aleksamc
REMAP function doesn't work was created by aleksamc
I try to study REMAP function and I read main
Doc
(Example for named parameter passing to NGC procedures)
but I get such error:
"NGC file not found: ngc=m400 - 45:REMAP = M400 modalgroup=10 argspec=Pg ngc=m400"
I make standart example:
1) I add to .ini file in [RS274NGC]
REMAP=M400 modalgroup=10 argspec=Pq ngc=400
2) Creat file <m400.ngc> in main linux configuration folder (also change it to standart nc-files
2.1) The code of it is from example:3) linux doesn't starts.
o<m400> sub
(P is required since it's uppercase in the argspec)
(debug, P word=#<P>)
(the q argspec is optional since its lowercase in the argspec. Use as follows:)
o100 if [EXISTS[#<q>]]
(debug, Q word set: #<q>)
o100 endif
o<m400> endsub
M2Please Log in or Create an account to join the conversation.
- Thank you received: 7468
27 Jan 2020 20:41 #155953
You need to have actual files named m400.ngc in the same folder as the config, if i remember correctly as it was some years ago i used remap.
Replied by tommylight on topic REMAP function doesn't work
- aleksamc
28 Jan 2020 06:12 #155977
by aleksamc
Replied by aleksamc on topic REMAP function doesn't work
Yes, I have them in the same folder as .ini file, but it doesn't found it.
What I do wrong I don't know?
- curtisa
- Thank you received: 15
28 Jan 2020 09:36 #155984
by curtisa
Replied by curtisa on topic REMAP function doesn't work
Pretty sure your 400.ngc file needs to be saved in the location specified under the SUBROUTINE_PATH parameter in the [RS274NGC] section of your INI file.
The following user(s) said Thank You: tommylight, aleksamc
- aleksamc
28 Jan 2020 11:48 #155998
by aleksamc
Yes, it's helped. Thanks a lot.
- aleksamc
28 Jan 2020 18:38 - 28 Jan 2020 19:14 #156037
by aleksamc
Last edit: 28 Jan 2020 19:14 by aleksamc. Reason: was my gramar fault
- aleksamc
28 Jan 2020 20:01 - 28 Jan 2020 20:41 #156041
by aleksamc
I try to continue my study of remap.
Now I stuck at python runnig program (first example)
1) In .ini file I write
REMAP=G88.6 modalgroup=1 argspec=XYZp python=g886
2) Then I created file g886.py in the same directory as ngc remapping files.
3) In file I write my program from standart example
4) I've got an error:I get such error if I complitly delete file from the folder also.
What problem could be?
I've read "4. Upgrading an existing configuration for remapping"
but still have problem
'g886' is not a Python callable function - 48:REMAP=G88.6 modalgroup=1 argspec=XYZp python=g886What problem could be?
Last edit: 28 Jan 2020 20:41 by aleksamc.
- satiowadahc
- Thank you received: 12
29 Jan 2020 03:38 #156064
by satiowadahc
Replied by satiowadahc on topic REMAP function doesn't work
Can you post your python code?
- aleksamc
29 Jan 2020 11:27 - 29 Jan 2020 11:30 #156080
by aleksamc
I added all necessary files. Now I'm very bad in python but I hope to study it using examples in technical docs.
What editor Can I use to write program for python? Using it in gedit is very inconvenient.
Last edit: 29 Jan 2020 11:30 by aleksamc.
- satiowadahc
30 Jan 2020 04:24 #156140
by satiowadahc
I may be mistaken but I believe your return needs to be indented on line 10.
Editor personal preference for general python is atom for generic writing, and pycharm for extreme debugging, but it doesn't work as nice when using linuxcnc
Time to create page: 0.132 seconds
