REMAP function doesn't work
- aleksamc
- Thank you received: 67
30 Jan 2020 09:12 #156154
by aleksamc
Replied by aleksamc on topic REMAP function doesn't work
I changed to
<return 0>
Nothing changed: " 'g886' is not a Python callable function.
May be it should be somehow compiled?
<return 0>
10 Feb 2020 00:17 #156920
Replied by andypugh on topic REMAP function doesn't work
Probably too late now (I have a huge forum backlog)
You probably need to make the Python files executable.
And they might also need themagic incantation at the top.
#! usr/env pythonPlease Log in or Create an account to join the conversation.
- aleksamc
16 Feb 2020 20:38 - 16 Feb 2020 20:42 #157519
by aleksamc
Thank's for your unswer AndyPugh. No, it's not late for me. I simply shifted this problem because I didn't found any answer.
I tried as you said:
1) added line <#! usr/env python> (also tried <#!/usr/bin/env python>)
2) in terminal writed chmod +x <filename.py>
But it doesn't solve my problem.
Last edit: 16 Feb 2020 20:42 by aleksamc.
19 Feb 2020 16:22 #157865
This looks like a problem with toplevel.py and remap.py. Do those both exist?
LinuxCNC loads toplevel.py and then that imports remap.py which needs to either contain your "involute" function definition, or import a file that does.
Time to create page: 0.193 seconds
