Gantry router with MESA 7I95
- keyboard
- Thank you received: 4
29 Jan 2020 18:31 #156102
by keyboard
Gantry router with MESA 7I95 was created by keyboard
Hello,
I'm in the process of building a router with Dual motors in the Y-axis. I'm planning on the MESA 7I95 for the 6-axis option ,when I later add rotary axes. That said , which flavour of LinuxCNC should I go with ?, Debian Stretch supports dual motor Gantry's, but does it support Mesa Ethernet interface boards ?
Thanks in advance for support.
- Thank you received: 1472
29 Jan 2020 20:57 - 29 Jan 2020 20:58 #156113
Replied by Todd Zuercher on topic Gantry router with MESA 7I95
The Linux distro used does not matter.
It does need to be using the Preempt-RT real time kernel when using Mesa Ethernet cards, not the RTAI one.
That said the Linuxcnc Stretch ISO available for download has the Preempt-RT kernel and Linuxcnc v2.7, so you should be good to go, once you updtate Linuxcnc to v2.8 or Master (Master might be required for the 7i95 which is a relatively new card)
Last edit: 29 Jan 2020 20:58 by Todd Zuercher.
Time to create page: 0.452 seconds
