Shaft gear that turns two gears?
- eiger3970
- Topic Author
6 years 9 months ago #156237
by eiger3970
Shaft gear that turns two gears? was created by eiger3970
I am trying to design a gear type that can turn two gears on one shaft.
E.g. Pinion/gear 1 turns for 2 or 4 seconds (a motor will control the 2 or 4 second shaft turn) and gear two turns for 30 seconds (whilst not turning gear 1 more than the 2 or 4 seconds)?
I have some ideas on how to make this work, but am not 100% clear just yet.
Any suggestions, as there's so many 'magical' gears out there that can do anything?
6 years 9 months ago #156243
Replied by rodw on topic Shaft gear that turns two gears?
If they are both turning at the same speed what about an electro mechanical clutch? Let it lock in one gear to the shaft for 2 or 4 seconds
6 years 9 months ago #156253
Replied by tommylight on topic Shaft gear that turns two gears?
Check some 3D printer extruders with 2 filaments and a single motor, they turn one or the other gear depending on motor direction, but the filament moves in the same direction in both cases.
6 years 8 months ago #157046
These might help: simplybearings.co.uk/shop/Bearings-Needl...9_31_4508/index.html
Replied by andypugh on topic Shaft gear that turns two gears?
eiger3970 wrote: I am trying to design a gear type that can turn two gears on one shaft.
6 years 8 months ago #157047
Or do you need a Geneva Motion?
It isn't clear if two gears rotate one shaft, or one shaft rotates two gears...
Time to create page: 0.050 seconds
