Spindle start turning at 200hz is It normal?
03 Feb 2020 22:43 #156479 by Tavares
Hello guys!
Iam using a chinese vfd xsy-at1 1.5kw, with 2.2kw spindle, the seller ship wrong vfd... ITs working but it start spin at 200hz 12000rpm, this is normal? Or i should buy another one? Im thinking to buy a 4kw vfd but a want no know If i can get Power rpm.
  • Moderator
  • Moderator
04 Feb 2020 12:01 #156492 by tommylight
Replied by tommylight on topic Spindle start turning at 200hz is It normal?
Check the users manual, there are settings for that on the VFD, but be warned that most of them do not like to go under 8000RPM.
04 Feb 2020 15:37 #156510 by Todd Zuercher
Replied by Todd Zuercher on topic Spindle start turning at 200hz is It normal?
That is the spindle would not be happy below 8000. The VFD should be ok at almost any speed. (if properly rated). That said, most spindles draw lots more current when running below their rated speed. That will be a big problem with your under spec drive. In theory though it should work ok most of the time until it over currents and either shuts down (if you're lucky) or goes poof.
I wouldn't trust the safety mechanisms built into most cheap Chinese electronics and often they under spec/overrate the components inside. I wouldn't count on the drive lasting long, at which point you can get a better one.
04 Feb 2020 15:59 #156512 by Clive S
Replied by Clive S on topic Spindle start turning at 200hz is It normal?
Hello guys!
Have you checked the parameters are set up correctly in the VFD as quite often the poles are wrong I think the poles should be 2 pole
there are also parameters to set the min. speed.
04 Feb 2020 17:51 #156526 by billykid
Replied by billykid on topic Spindle start turning at 200hz is It normal?
yes I also read that under 8000 rpm they risk to burn ... but I also heard that you should not start cold at maximum speed because the bearings suffer ...
04 Feb 2020 18:08 #156530 by Todd Zuercher
Yes it is generally a good idea to warm them up for a bit. 5 to 10min. at 1/2 rated speed is usually good. Giving them a good run in when new is also a good idea. Running in a spindle properly can take a long time.
07 Feb 2020 05:32 #156675 by Tavares
Replied by Tavares on topic Spindle start turning at 200hz is It normal?
tnx guys! i talk to the manufacture they say 200hz to 400hz is right!
07 Feb 2020 08:30 #156682 by bbsr_5a
Replied by bbsr_5a on topic Spindle start turning at 200hz is It normal?
The China VFD like Hyanyang want at least 6000RPM and then you will need soft Cheese material
on Hard Gouda it will stop Milling
Personly i prefer a MIN of 12000RPM
If you build a Steel Milling Machine you need a 2KW 1440RPM Simple E-Motor at 120USD that can be also connected to the VFD as UVW
10 Feb 2020 05:15 #156934 by Tavares
i try to mill steel but it burn the endmill its was a HSS 8mm flat endmill without coating.
10 Feb 2020 06:45 #156937 by Hakan
Get yourself a Feeds and speeds calculator
An 8mm HSS end mill should run at about 1000 rpm. Your spindle runs way to fast for that and yes will burn the end mill.
You can try a 3mm carbide end mill. 12000 rpm is about right for that.
Time to create page: 0.371 seconds
