new to linuxcnc and building a plasma table
  • jay1st
  • jay1st's Avatar Topic Author
  • Premium Member
  • Premium Member
10 Feb 2020 14:02 #156954 by jay1st
Hi guys
I'm currently making my own plasma cutting rig
Already purchased a Mesa 7i96 + THCAD10 (after an email to MESA) and most of the hardware
Planning to use LinuxCNC + Plasmac + Sheetcam
As a starting base a machine shop gave me a laser CO2 machine (80w + 150w) 1,2m x 1.5m, it's been sitting outdoors for a couple of months under the rain so i'm only keeping the chassis, the 80w tube is working and the 150 has blown the HV power supply ( i guess the tube as well) + the electronics that are underneath protected from the weather.
But i'm confused about my software selection, if it's correct or not ?
25 years since i touched a CAD software, might take the Freecad route as it seems less complicated than F360
10 Feb 2020 14:07 #156957 by bbsr_5a
Replied by bbsr_5a on topic new to linuxcnc and building a plasma table
Sheetcam is great for plasma use
the Shop center here with 10 Plasma laser waterjets use only sheetcam and linuxcnc
you are well inside what you are lookiung for
  • jay1st
  • Premium Member
  • Premium Member
10 Feb 2020 15:34 #156962 by jay1st
Replied by jay1st on topic new to linuxcnc and building a plasma table
Ok good to know, but i'm confused about Plasmac, i have to install it or is it included in the latest LinuxCNC ?
10 Feb 2020 16:32 #156969 by Clive S
Replied by Clive S on topic new to linuxcnc and building a plasma table
Have you seen this forum.linuxcnc.org/plasmac/37234-plasmac-documentation
PlasmaC is in Linuxcnc 2.9 and I think 2.8
The following user(s) said Thank You: jay1st
10 Feb 2020 19:34 #156981 by AgentWD40
Replied by AgentWD40 on topic new to linuxcnc and building a plasma table
If you're just making flat parts you can also take a look at librecad. librecad.org/
  • jay1st
  • Premium Member
  • Premium Member
11 Feb 2020 07:26 #157024 by jay1st
Tnx, i had a look at it, seems pretty simple but i installed it to try out and lacking in versatility, cant round corners once the object is made as it' not parametric. Other than that it's perfect for simple shapes.
Has anyone tryied Frontplatten ? free and made for front plate designs.
I'll give it a shot tonight.
  • jay1st
  • Premium Member
  • Premium Member
11 Feb 2020 07:54 #157025 by jay1st
nevermind what i said about librecad, finally foud how to do it :) stupid noob me ;)
  • jay1st
  • Premium Member
  • Premium Member
13 Feb 2020 09:30 #157270 by jay1st
Quick question, i've read the entire LinuxCNC plasma primer, and for the table my side it recommends using a belt drive, but any DIY plasma table i see over inter net has rack and pinion drive............;
Is it that bad to use belts ? As i already have them, 20mm wide, on the laser ssystem i was given, it even has a belt driven reducter 5not sure about the proper term to use).
  • Moderator
  • Moderator
13 Feb 2020 10:29 #157274 by tommylight
Replied by tommylight on topic new to linuxcnc and building a plasma table
Most of my plasma machines use belts.
Search youtube for
Toma berisha
My channel is the first result.
  • jay1st
  • Premium Member
  • Premium Member
13 Feb 2020 12:24 #157281 by jay1st
Search youtube for
Toma berisha
Yeha i've been watching those, and i see you're in direct drive on the gantry, is it fast enough ?
Time to create page: 0.132 seconds
