Modern/compact linuxcnc setup
- Hakan
- Thank you received: 454
12 Feb 2020 12:27 - 12 Feb 2020 12:33 #157174
by Hakan
Replied by Hakan on topic Modern/compact linuxcnc setup
Not a guru but one typically would use the 7i85s daughter board. Or all-in-one with the 7i95.
Look for the 25-pin fpga expansion connector. I use 7i76e+7i85s combo but many variants will work like 7i96+7i85s.
Ethernet gives flexibility, I tried the 7i76e on the Rpi4 with good result.
I think one can have somewhat faster servo-thread (2-3 kHz?) with pcie, but never felt a need to go faster than the default 1 kHz.
Last edit: 12 Feb 2020 12:33 by Hakan.
- Thank you received: 4652
26 Feb 2020 23:30 #158581
If you want one, check out the mini-itx.com "board finder"
www.mini-itx.com/store/category?type=mot...&sortby=price&page=1
Right at the bottom on the left you can choose parport or parport header (if you choose both there will be no results)
Replied by andypugh on topic Modern/compact linuxcnc setup
I've looked around and unfortunately there are not many mobos that come with a parallel port today.
Time to create page: 0.069 seconds
