RaspberryPi 3: remote axis display?
- twoflowers
- Visitor
Now running linuxcnc on X11, I get
Unexpected realtime delay on task 0 with period 50000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
task: 2129 cycles, min=0.000049, max=0.034770, avg=0.010206, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Note: Using POSIX realtime
But I still get a realtime error message on the display. ( Does anybody know what causes this message? )
Anyway, when I run the GUI remote over ssh -X ..., I do not get any trealtime error message - but the 3D preview is "a bit" sluggish.
So the question: Does anybody k now how to run axis on my local computer and make it control the romote axis (or linuxcnc) instance?
- bbsr_5a
- Thank you received: 106
the error you get is as Ferror i think yoiu shoudt use a 100000 base in first place
even if the latency jumps to 200k it will give you a stepper setup at max 3m/min at 100steps/mm
We got crappy PC here and they run since long time on this setup dayly
- twoflowers
- Visitor
The realtime error occurs immediately after starting axis, even before the machine is turned on, but it does not occur over ssh. I think it's the GPU that causes trouble, so I'd like to run the axis GUI-part on my PC and the controlling part on the RPi.
- Thank you received: 7468
Servo thread should be fine.
- twoflowers
- Visitor
Beware that RPI3 has the ethernet port internally wired through a USB port so the latency/ delay is terrible .
- twoflowers
- Visitor
To clearify: what kills latency on the RPi3 is opengl, not the usb-stuff.
I just came across "linuxcncrsh", but I still need a way to connect "some" gui -preferably axis - to it. Any idea?
- Thank you received: 4652
Then just start linuxCNC from the command line.
- twoflowers
- Visitor
