Homming In Automatic Mode ?
  • snujcnc
  • snujcnc's Avatar Topic Author
  • Senior Member
  • Senior Member
28 Feb 2020 03:29 #158721 by snujcnc
Homming In Automatic Mode ? was created by snujcnc
i am looking for home operation done when machine in auto mode or mdi mode
tried halui.joint.N.home whem in mdi or auto mode it show error machine not in manual mode
(G28 and G30 not useful to me i need home like manual mode during automode)
please make comment
28 Feb 2020 06:03 #158725 by cmorley
Replied by cmorley on topic Homming In Automatic Mode ?
Do need to actually home the machine or just move to home?
If you need to actually home in Auto mode, can you explain why?
  • snujcnc
  • Senior Member
  • Senior Member
28 Feb 2020 08:23 #158733 by snujcnc
Replied by snujcnc on topic Homming In Automatic Mode ?
I am using Spindle and C axis on same motor (same drive servo)
so when i switch from turning(c axis) to milling(turning) i reset position count of spindle feedback encoder
this process i can do with m code in auto program
but when i reset position count of servo motor encode i need to find zero position of c axis
and for that i can do in manual mode but if i want to find c axis actual home i want to run home sequence in auto mode
( i try to explain my requirement please ask if you not understand )
Time to create page: 0.437 seconds
