Turn on and off "axis.N.amp−enable−out"
- snujcnc
- Thank you received: 4
28 Feb 2020 03:35 #158722
by snujcnc
Turn on and off "axis.N.amp−enable−out" was created by snujcnc
I want to turn off and on "axis.N.amp−enable−out" with classic ladder
when i press emergency all axis "axis.N.amp−enable−out" going to low but i want to on and off only one "axis.N.amp−enable−out"
any comment
any comment
- Thank you received: 2175
28 Feb 2020 06:01 #158724
Replied by cmorley on topic Turn on and off "axis.N.amp−enable−out"
Not currently possible - but you could use classicladder to enable the amps.
so axis.0.amp−enable−out goes into classicladder and you use classicladder outputs to enable your amps.
Why do you wish to disable one amp but not the others?
- snujcnc
28 Feb 2020 08:30 #158734
by snujcnc
Replied by snujcnc on topic Turn on and off "axis.N.amp−enable−out"
>>ok got it thanks
>>i actually use classiclader to enable servo amps.
if i disable "axis.0.amp−enable−out" i found that position command to servo drive become zero and this is very use full when we use c axis and spindle on same motor
when i switch from spindle to c axis i apply emergency(io control) for 100 ms and
and remove so i found that axis position command become zero
and same time i reset my motor feedback value zero inside servo drive
so migration c axis to spindle become easy
i need this for c axis only thats why i ask for only one axis out put disable
hope you understand my requirement
>>ok got it thanks
28 Feb 2020 16:57 #158765
Yes that makes perfect sense.
I would still have axis.0.amp−enable−out go into classicladder to kill your C axis if the machine is turned off/estopped.
Chris
Chris
- Mike_Eitel
- Thank you received: 183
28 Feb 2020 19:10 #158778
by Mike_Eitel
Replied by Mike_Eitel on topic Turn on and off "axis.N.amp−enable−out"
I have a four axis config but use a very seldom. In fact it is even plugable and so i have the driver normaly disabled via enable pin. XYZ enabled when in machine on, A only via toggle. All solved in ladder.
