- LinuxCNC
- General LinuxCNC Questions
- pncconf from 2.8.0~pre1 vs pncconf from 2.8.0.pre1.4891.gadf1eff73
- BeagleBrainz
- Visitor
29 Feb 2020 10:13 #158799
by BeagleBrainz
If I install linuxcnc from package built from git on or about 13 Feb and copy pcconf app and /usr/lib/python/dist-packages/pcconf directory from 2.8.0.pre1.4891.gadf1eff73 (from rtai testing from andypugh github) pncconf runs fine and can select firmwares.
To get the pncconf stuff i expand this deb github.com/andypugh/RTAI/releases/downlo...gadf1eff73_amd64.deb
pncconf from 2.8.0~pre1 vs pncconf from 2.8.0.pre1.4891.gadf1eff73 was created by BeagleBrainz
- pncconf from 2.8.0~pre1 has issues if hostmot2 firmware is installed (no issues without except for message saying no firmware installed)
- pncconf from 2.8.0.pre1.4891.gadf1eff73 appears to work as it should
- bbsr_5a
- Thank you received: 106
29 Feb 2020 16:46 #158822
by bbsr_5a
Replied by bbsr_5a on topic pncconf from 2.8.0~pre1 vs pncconf from 2.8.0.pre1.4891.gadf1eff73
the wizard is updated nearly every day
- BeagleBrainz
- Visitor
29 Feb 2020 18:06 #158827
by BeagleBrainz
In what way is this helpful ?
Replied by BeagleBrainz on topic pncconf from 2.8.0~pre1 vs pncconf from 2.8.0.pre1.4891.gadf1eff73
- Thank you received: 2181
29 Feb 2020 18:13 #158829
What are the issues? error messages? How did you install firmware? What boards are you installing firmware for.
Chris
Replied by cmorley on topic pncconf from 2.8.0~pre1 vs pncconf from 2.8.0.pre1.4891.gadf1eff73
Chris
- BeagleBrainz
- Visitor
29 Feb 2020 21:53 #158844
by BeagleBrainz
Hi Chris
Error Message:
Running pncconf -d alldev has this up to the point where I select from internal data to 5i23
After clicking Accpet Compoment Changes this is the next message box message
Firmwares source was linuxcnc.org/dists/stretch/base/binary-amd64/
I'm trying to straighten out the images I made for Mint.
One thing of note on my main box & laptop I have Mint 18.3 and have Linuxcnc installed I built from packages from git source from around July of 2019. Those packages have no issues. Best I can give is that the getting stated guide is dated 2019-07-14. Unfortunately linuxcnc_info only gives the version as LINUXCNCVERSION: 2.8.0-pre1~ on the Mint 18.3 Box
The version with the error is 2.8.0-pre1-5437-g8882fd41c on Linux Mint 19.2
Error Message:
PNCconf encountered an error. The following information may be useful in troubleshooting:
LinuxCNC Version: UNAVAILABLE
File "/usr/bin/pncconf", line 1989, in on_mesa_boardname_changed
self.fill_firmware(boardnum)
File "/usr/bin/pncconf", line 1998, in fill_firmware
self.mesa_firmware_search(title)
File "/usr/bin/pncconf", line 895, in mesa_firmware_search
self._p.FIRMDIR,boardtitle,currentfirm+".xml"))
File "/usr/bin/pncconf", line 943, in parse_xml
meta = self.get_board_meta(currentboard)
NameError: global name 'currentboard' is not definedRunning pncconf -d alldev has this up to the point where I select from internal data to 5i23
rmurphy@VBox-M90P:~/hostmot2-firmware$ pncconf -d alldev
alldev
PNCconf debug alldev
loading glade page REFERENCE:start TITLE:Start INIT STATE: True STATE:True
loading glade page REFERENCE:base TITLE:Base Information INIT STATE: True STATE:True
loading glade page REFERENCE:screen TITLE:Screen INIT STATE: True STATE:True
loading glade page REFERENCE:vcp TITLE:VCP INIT STATE: True STATE:True
loading glade page REFERENCE:external TITLE:External Controls INIT STATE: True STATE:True
loading glade page REFERENCE:mesa0 TITLE:Mesa Card 0 INIT STATE: False STATE:True
loading glade page REFERENCE:mesa1 TITLE:Mesa Card 1 INIT STATE: False STATE:True
loading glade page REFERENCE:pport1 TITLE:Parallel Port INIT STATE: False STATE:True
loading glade page REFERENCE:pport2 TITLE:Parallel Port 2 INIT STATE: False STATE:True
loading glade page REFERENCE:x_motor TITLE:X Motor INIT STATE: True STATE:True
loading glade page REFERENCE:x_axis TITLE:X Axis INIT STATE: True STATE:True
loading glade page REFERENCE:y_motor TITLE:Y Motor INIT STATE: True STATE:True
loading glade page REFERENCE:y_axis TITLE:Y Axis INIT STATE: True STATE:True
loading glade page REFERENCE:z_motor TITLE:Z Motor INIT STATE: True STATE:True
loading glade page REFERENCE:z_axis TITLE:Z Axis INIT STATE: True STATE:True
loading glade page REFERENCE:a_motor TITLE:A Motor INIT STATE: True STATE:True
loading glade page REFERENCE:a_axis TITLE:A Axis INIT STATE: True STATE:True
loading glade page REFERENCE:s_motor TITLE:Spindle Motor INIT STATE: True STATE:True
loading glade page REFERENCE:options TITLE:Options INIT STATE: True STATE:True
loading glade page REFERENCE:realtime TITLE:Realtime INIT STATE: True STATE:True
loading glade page REFERENCE:finished TITLE:Almost Done INIT STATE: True STATE:True
FWD search 1,start,Start,True,True,of 21 pages
set 1 current
FWD search 2,base,Base Information,True,True,of 21 pages
page_set_state() ['options', 'external', 'realtime'] ,False
external State changed to False
options State changed to False
realtime State changed to False
****folder added :5i20
****folder added :3x20-1
****folder added :5i22-1
****folder added :5i22-1.5
****folder added :7i43-2
****folder added :7i43-4
****folder added :5i23
set 2 current
FWD search 3,screen,Screen,True,True,of 21 pages
page_set_state() mesa1 ,False
mesa1 State changed to False
page_set_state() x_axis ,True
x_axis State changed to True
page_set_state() x_motor ,True
x_motor State changed to True
page_set_state() s_axis ,True
page_set_state() s_motor ,True
s_motor State changed to True
page_set_state() y_axis ,True
y_axis State changed to True
page_set_state() y_motor ,True
y_motor State changed to True
page_set_state() z_axis ,True
z_axis State changed to True
page_set_state() z_motor ,True
z_motor State changed to True
page_set_state() a_axis ,False
a_axis State changed to False
page_set_state() a_motor ,False
a_motor State changed to False
page_set_state() pport1 ,False
pport1 State changed to False
page_set_state() pport2 ,False
pport2 State changed to False
set 3 current
FWD search 4,vcp,VCP,True,True,of 21 pages
set 4 current
FWD search 5,external,External Controls,True,False,of 21 pages
Page external skipped
FWD search 6,mesa0,Mesa Card 0,False,True,of 21 pages
Loading page mesa0
**** INFO firmware 0 changed
Looking for firmware data 7i76x2 -With One 7i76
0,7i76x2
1,7i76x2 -With One 7i76
found firmware # 1
set 6 current
SVST8_4IM2.xml
TPEN6_6.xml
SVST8_8IM2.xml
SVST8_4.xml
SVTP6_7I39.xml
SVST2_4_7I47.xml
SV12.xml
SVST4_8.xml
XML list:['SVST8_4IM2', 'TPEN6_6', 'SVST8_8IM2', 'SVST8_4', 'SVTP6_7I39', 'SVST2_4_7I47', 'SV12', 'SVST4_8']
File "/usr/bin/pncconf", line 2352, in on_mesa_component_value_changed
self.set_mesa_options(boardnum,title,firmware,numofpwmgens,numoftppwmgens,numofstepgens,numofencoders,numofsserialports,numofsserialchannels)
File "/usr/bin/pncconf", line 2380, in set_mesa_options
dbg('current firmware:\n%r'%self._p.MESA_FIRMWAREDATA[search],mtype='curfirm')
UnboundLocalError: local variable 'search' referenced before assignmentFirmwares source was linuxcnc.org/dists/stretch/base/binary-amd64/
Setting up hostmot2-firmware-7i43-4 (0.8.21.g5be856c) ...
Setting up hostmot2-firmware-4i65 (0.8.21.g5be856c) ...
Setting up hostmot2-firmware-5i23 (0.8.21.g5be856c) ...
Setting up hostmot2-firmware-4i68 (0.8.21.g5be856c) ...
Setting up hostmot2-firmware-5i20 (0.8.21.g5be856c) ...
Setting up hostmot2-firmware-5i22-1 (0.8.21.g5be856c) ...
Setting up hostmot2-firmware-7i43-2 (0.8.21.g5be856c) ...
Setting up hostmot2-firmware-3x20-1 (0.8.21.g5be856c) ...
Setting up hostmot2-firmware-5i22-1.5 (0.8.21.g5be856c) ...
Setting up hostmot2-firmware-all (0.8.21.g5be856c)I'm trying to straighten out the images I made for Mint.
29 Feb 2020 22:00 #158845
thanks for the info - i haven't tested that type of firmware loading in a long time - most people use the newer versions of mesa cards.
I'll look into it.
Chris
I'll look into it.
Chris
The following user(s) said Thank You: BeagleBrainz
29 Feb 2020 22:21 #158846
If you change line 943 from:
to;
That should fix it.
I'll push the fix - if you can confirm..
Chris
meta = self.get_board_meta(currentboardname)to;
meta = self.get_board_meta(boardname)That should fix it.
Chris
- BeagleBrainz
- Visitor
29 Feb 2020 22:21 - 29 Feb 2020 22:32 #158847
by BeagleBrainz
I'm just trying to dot all the Is and cross all the Ts.
If they aren't really needed I can remove those firmwares.
Seems to fix the issue, no way to test but I'll post the ini & hal if that's any help
Last edit: 29 Feb 2020 22:32 by BeagleBrainz. Reason: Tested fix
29 Feb 2020 22:24 #158848
They are if one uses the older boards 5120,7i43 etc that load firmware each time they start.
Chris
Chris
- LinuxCNC
Time to create page: 0.260 seconds
