MULT2 OFFSET omp problem
  • bkt
  • bkt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
10 Mar 2020 19:06 #159689 by bkt
MULT2 OFFSET omp problem was created by bkt
sorru guys ... why these is erroneus?
net x-pos-cmd       =>  pid.x.command mult2.0.in0
setp   mult2.0.in1  -1.0
net offset.0.offset	<=   mult2.0.out
linuxcnc send these error messages:
offset.0.offset not be the same as pin ...
bkt
10 Mar 2020 19:31 - 10 Mar 2020 19:31 #159691 by PCW
Replied by PCW on topic MULT2 OFFSET omp problem
It likely means you have a pin offset.0.offset in your system
You cannot connect a pin to a pin without using a signal
If a pin offset.0.offset exists:
net my-offset0 offset.0.offset <= mult2.0.out
is legal, but
is not
Last edit: 10 Mar 2020 19:31 by PCW.
Time to create page: 0.079 seconds
