Limit Switch Handling
- Project_Hopeless
- Thank you received: 10
11 Mar 2020 15:34 - 11 Mar 2020 15:35 #159778
by Project_Hopeless
Limit Switch Handling was created by Project_Hopeless
If I use Pconf or 7i96 tool and assign limit switches for over travel X, Y, Z using the pre defined I/O, is that all that is required? There is no HAL ladder logic to write, the limits are handled automatically?
www.forum.linuxcnc.org/27-driver-boards/...ol?start=0#gallery-9
Is the same true for a generic/simple E-Stop input?
Last edit: 11 Mar 2020 15:35 by Project_Hopeless.
- Thank you received: 7468
11 Mar 2020 16:08 #159780
Replied by tommylight on topic Limit Switch Handling
Yes and yes.
Usually.
Usually.
- bbsr_5a
- Thank you received: 106
11 Mar 2020 18:02 #159788
by bbsr_5a
Replied by bbsr_5a on topic Limit Switch Handling
you can also use only one pin for all REF or even all Switches if there are in a chain mounted
or like the LJ12A3-4-Z-BX sticht together to one relay and that triggers the pin
Time to create page: 0.553 seconds
