INI goes to VIM
14 Mar 2020 10:02 #160154 by upcut4d
INI goes to VIM was created by upcut4d
I have modified Denford Starmill , changing all electronics, no problems. Loaded version 2.7.14 and have completed Stepconf Wizard and everything appears to be good. Now l go to the INI file to change offsets and l get coloured text in VIM, somethings wrong ! Help, thanks.
  • Moderator
  • Moderator
14 Mar 2020 11:48 #160160 by tommylight
Replied by tommylight on topic INI goes to VIM
What is the problem ?
Having colors in text editors is not a problem, most of them do that so it is easier to follow stuff while editing.
14 Mar 2020 12:37 #160163 by bbsr_5a
Replied by bbsr_5a on topic INI goes to VIM
use GEDIT if you do not want colors
15 Mar 2020 14:42 #160309 by upcut4d
Replied by upcut4d on topic INI goes to VIM
Ok, that sounds good, however if l try to change the value offset by highlighting then deleting, l cannot add a number! Or if l highlight the type a number, it doesn't work! Any pointers would be much appreciated.
15 Mar 2020 14:49 #160310 by upcut4d
I was expecting black on white text! However l am not able to alter offsets for example by highlighting then deleting, cant input new figure! thank you for your time.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
15 Mar 2020 17:39 #160319 by BeagleBrainz
Replied by BeagleBrainz on topic INI goes to VIM
Install geany
Use geany
Geany good
Geany multi tab
Geany easy
Geany not be made by the dumbs
Seriously geany is a great editor
Or if you prefer a console text editor , install mc (midnight commander).
Start mc find you file, press F4 on your highlighted file and start editing. I tend to do most things with mc
Time to create page: 0.163 seconds
