- Thank you received: 4
Need help with unexpected/random stops on basic Parport/5 axis BOB setup
- Lezard
6 years 7 months ago - 6 years 7 months ago #160186
by Lezard
Replied by Lezard on topic Need help with unexpected/random stops on basic Parport/5 axis BOB setup
Ok, so I'm at the shop now, trying to move forward on this.
Keyboard/mouse : couldn't find a spare USB combo at the moment, and the PC (Dell Optiplex 760) has no PS/2 connections. Tried the next best thing I could think of and unplugged the USB keyboard and mouse after I launched LinuxCNC and got the spindle running idle. Machine stopped after +/- 10 minutes.
Stopped the PC and moved its power supply to a wall socket outside the CNC cabinet, replugged USB keyboard and mouse, restarted everything. I'm now waiting to see if/when it stops running...
One thought : I have added a WLAN card the Optiplex to help set it up, as I had no wired Ethernet available in the office. It's still in the machine. Can this thing create EMI ? Should I deactivate it ?
Thank you for reading me, and for your help
Laurent
Laurent
Last edit: 6 years 7 months ago by Lezard. Reason: fixed typo
- Thank you received: 7491
6 years 7 months ago #160187
Replied by tommylight on topic Need help with unexpected/random stops on basic Parport/5 axis BOB setup
Yes it does a lot, but not powerful enough to cause any issues regarding this.Lezard wrote: ......... Can this thing create EMI ?...........
- Lezard
6 years 7 months ago - 6 years 7 months ago #160190
by Lezard
OK,
So, I also checked the neutral/phase being possibly reversed : it seems OK.
The machine has been running for a while now, with the PC powered from a wall socket outside the CNC cabinet. But again, this is random, so could stop in a few minutes, or in one hour
- Lezard
6 years 7 months ago #160191
by Lezard
My friend suggested that the PC should be powered from inside the CNC cabinet, in particular because the Bob gets its 5v power from the PC USB.
I did not understand exactly why, but I trusted his judgment. What would you say ?
- Clive S
- Thank you received: 486
6 years 7 months ago #160193
by Clive S
I never power a bob from a usb and not from a usb charger either as the smart ones control the charging current with hand shaking
Best to use a small 5V power supply
Replied by Clive S on topic Need help with unexpected/random stops on basic Parport/5 axis BOB setup
Lezard wrote: My friend suggested that the PC should be powered from inside the CNC cabinet, in particular because the Bob gets its 5v power from the PC USB.
- Lezard
6 years 7 months ago - 6 years 7 months ago #160195
by Lezard
OK, I'll also try this as well. I should have some sort of small standard PSU used for appliances, could this be worth a try before I get a proper one ?
I need to move now, will continue testing over the week-end and report here. Thank you all for your help
Time to create page: 0.150 seconds
