- LinuxCNC
- General LinuxCNC Questions
- spindle on not able to set to unused pin using pncconfig after setting
- CNCFred
- Thank you received: 43
16 Mar 2020 15:45 #160435
by CNCFred
spindle on not able to set to unused pin using pncconfig after setting was created by CNCFred
this is just for information:
pncconfig does not unset the spindel on pin if set to unused in a later run.
I unfortunately used the spindle setting before using plasmac but deleting the pin in a later run does not delete the entry.
has to manually be #
- Thank you received: 2175
17 Mar 2020 09:19 #160525
Replied by cmorley on topic spindle on not able to set to unused pin using pncconfig after setting
Do you mean spindle-enable?
I can't replicate this or I don't understand what is sticking around.
Could you post a .pncconf file that shows the problem?
- LinuxCNC
Time to create page: 0.234 seconds
