Puma560 - Geometry and building other 6 axis robots
- Thank you received: 4652
30 Mar 2020 22:40 #162174
Replied by andypugh on topic Puma560 - Geometry and building other 6 axis robots
How do you feel about that being added to the LinuxCNC docs?
- Thank you received: 2164
31 Mar 2020 05:54 - 31 Mar 2020 07:32 #162203
Replied by Aciera on topic Puma560 - Geometry and building other 6 axis robots
absolutely, that would be an honour.
I just noticed that the explanation of parameter A-5 is missing. I will fix that.
@andy: The PDF is fixed and ready for you.
Last edit: 31 Mar 2020 07:32 by Aciera.
- dgarrett
- Thank you received: 297
01 Apr 2020 16:41 #162357
by dgarrett
Replied by dgarrett on topic Puma560 - Geometry and building other 6 axis robots
@Aciera re: ini hal pins
ini hal pins are available for both JOINT_N and AXIS_L
MIN_LIMIT,MAX_LIMIT,MAX_ACCELERATION, MAX_VELOCITY
See the milltask man page (especially notes at bottom):
linuxcnc.org/docs/master/html/man/man1/milltask.1.html
In general, an interp-motion sync is needed for ini hal pins
to be recognized for subsequent motion but the sync is
needed to switch kins types anyway.
Recent dgarr/s_kins docs (not commited yet):
www.panix.com/~dgarrett/stuff/switchkins.html
See 3.3 Inifile Limit settings
And intree examples for M128,...:
github.com/LinuxCNC/linuxcnc/blob/dgarr/...ach/puma/mcodes/M128
Is there a way to alter the min- and max-axis limits
- dgarrett
08 Apr 2020 14:55 #163202
by dgarrett
@Aciera
I converted your pdf to the asciidoc format used for
LinuxCNC docs and made a branch dgarr/dhtxt for test.
Ref: github.com/LinuxCNC/linuxcnc/blob/dgarr/...on/dh-parameters.txt
Rendered in html:
www.panix.com/~dgarrett/stuff/dh-parameters.html
The dh-parameters.txt file includes your images from the
pdf but would benefit from some introductory and explanatory
text. If interested, please review the document and
supply any additional text to me.
The easiest way is to send an edited copy of the
dh-parameters.txt file to me:
d g a r r e t t at panix dot com
Rendered in html:
Time to create page: 0.298 seconds
