Good evening people,
Sorry to bother you , but now that the whole country (Argentina) is locked down and quarantined it looks like I came back to my robotics project :laugh: :laugh: .
I need to print out in the console the JOINT values from a PUMA560. I believe that's using
genserkins, so I was checking the code and it seems my C is kind of rusty.
I was checking:
- go_matrix
- GO_MATRIX_DECLARE
to be honest, I don't really understand how it works though.
So my question is, can someone with better understanding can point me out HOW I should print the JOINT values for the robot?
What I like to print is just all the joints something like:
printf("%lf,%lf,%lf,%lf,%lf,%lf\n", JT[0], JT[1], JT[2], JT[3], JT[4], JT[5]);
I know the code above is wrong, but that's the idea and (it's embarrassing) but I did not get how to print those. I wanted to do that inside the
compute_jinv, but anywhere it's fine.
My idea is to print the 6 values all the time... (Yes, I understand I will probably make the robot REALLY slow, because that's called all the time, or very often), but I will put that into a file, run a G-CODE, and exit.
Then I will use those values to do some math stuff outside.
THANK YOU VERY MUCH.
Cheers
Félix
