Installing MESA card 5i25
20 Mar 2020 20:15 #160936 by prochj51
Installing MESA card 5i25 was created by prochj51
I have been trying to install 5i25 MESA card. I am planning to use with 7i76. So I install driver as followed:
sudo mesaflash --device 5I25 --write 5i25_7i76x2.bit
with output:
Checking file... OK
  File type: BIT file
Boot sector OK
EEPROM sectors to write: 6, max sectors in area: 16
Erasing EEPROM sectors starting from 0x100000...
  |EEEEEE
Programming EEPROM sectors starting from 0x100000...
  |WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration updated successfully.
You must power cycle board or use --reload command to load updated firmware.
They I am trying to verify it and getting
sudo mesaflash --device 5I25 --verify 5i25_7i76x2.bit
Checking file... OK
  File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x100000...
  |VVVVV
Error at 0x10AA24 expected: 0x80 but read: 0x8
I dont really know what is happening or how to fix it.
Thanks for help
Jiri
20 Mar 2020 20:42 #160941 by PCW
Replied by PCW on topic Installing MESA card 5i25
Are you using the latest mesaflash?
Some older versions had issues with 64 bit OS's
github.com/jethornton/mesaflash
is the latest
Does retrying work?
21 Mar 2020 07:32 #160966 by prochj51
Replied by prochj51 on topic Installing MESA card 5i25
I clone the directory as you suggested but I got following output
eeprom_local.c:21:21: fatal error: pci/pci.h: No such file or directory
I am on Ubuntu 16.04 RTAI
Jiri
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
21 Mar 2020 09:14 #160972 by BeagleBrainz
Replied by BeagleBrainz on topic Installing MESA card 5i25
packages.ubuntu.com/xenial/libpci-dev
Basically you can use google to search for the missing file & what package it belongs to
or you can try this
apt contains "pci/pci.h"
21 Mar 2020 09:51 #160974 by prochj51
I installed
sudo apt-get install libpci-dev
with succes
but when I run make on mesaflash this happens:
make
gcc -o mesaflash mesaflash.o libanyio.a -lpci -lm
/usr/bin/ld: i386:x86-64 architecture of input file `libanyio.a(usb_boards.o)' is incompatible with i386 output
/usr/bin/ld: i386:x86-64 architecture of input file `libanyio.a(pci_boards.o)' is incompatible with i386 output
/usr/bin/ld: i386:x86-64 architecture of input file `libanyio.a(sserial_module.o)' is incompatible with i386 output
/usr/bin/ld: i386:x86-64 architecture of input file `libanyio.a(spi_boards.o)' is incompatible with i386 output
/usr/bin/ld: i386:x86-64 architecture of input file `libanyio.a(serial_boards.o)' is incompatible with i386 output
collect2: error: ld returned 1 exit status
Makefile:70: recipe for target 'mesaflash' failed
make: *** [mesaflash] Error 1
I am on 32 bit environment
21 Mar 2020 10:14 #160975 by prochj51
Okey, I had some old object files.
Now it works.
Thanks a lot guys!
Time to create page: 0.126 seconds
