looking for syntax for .axisrc file to bind a key to run O code (.ngc file)
  • Muscats
  • Muscats's Avatar Topic Author
  • Junior Member
  • Junior Member
05 Apr 2020 13:21 #162766 by Muscats
I am looking for the correct syntax to use in an .axisrc file to bind a key to run O code (.ngc file)?
I have been googling this for the past couple of days and cannot get anything that works. I am using LinuxCNC2.8.
I have setup Z touch off by following this 7xcnc.com/software/probing/z-touch-plate/
I currently have the following line in my .axisrc file, which does not work
root_window.bind("<XF86HomePage>", c.mdi("o100 call"))
If I manually run o100 call in MDI it works
I have a PYVCP button in AXIS and clicking on that works too.
I just can't get it to launch of keypress on my wireless keyboard/pendant
I tested the key binding using this
root_window.bind("<XF86HomePage>", "destroy .") and the key bind works,
I just need to get the key bind to launch the o100 file, all suggestions greatly excepted
05 Apr 2020 13:45 #162768 by MaHa
06 Apr 2020 03:00 - 06 Apr 2020 03:01 #162835 by phillc54
You may need to call a function then put your commands in the function, something like:
def my_button_function(event):
    ensure_mode(linuxcnc.MODE_MDI)
    c.mdi("o100 call")
root_window.bind("<XF86HomePage>", my_button_function)
Last edit: 06 Apr 2020 03:01 by phillc54. Reason: change button name
The following user(s) said Thank You: Muscats
  • Muscats
  • Junior Member
  • Junior Member
06 Apr 2020 03:04 #162836 by Muscats
    c.mdi("o100 call")
does all of that go in the .axisrc file?
06 Apr 2020 03:05 #162837 by phillc54
Yes and in that order.
  • Muscats
  • Junior Member
  • Junior Member
06 Apr 2020 03:09 #162838 by Muscats
thanks, will give it a try
  • Muscats
  • Junior Member
  • Junior Member
06 Apr 2020 04:14 #162844 by Muscats
    c.mdi("o100 call")
this worked perfectly, thank you
Time to create page: 0.193 seconds
