unwanted radiusing in LinuxCNC 2.8
- Hakan
- Thank you received: 454
11 Apr 2020 07:38 #163582
by Hakan
Replied by Hakan on topic unwanted radiusing in LinuxCNC 2.8
And don't forget that the G64 setting is lost when emergency stop is activated.
The following user(s) said Thank You: jferguson
- jferguson
- Thank you received: 5
13 Apr 2020 15:48 #163878
by jferguson
Replied by jferguson on topic unwanted radiusing in LinuxCNC 2.8
I reduced RS274NGC_STARTUP_CODE = G17 G20 G40 G49 G64 P0.001 G80 G90 G92 G94 G97 G98
to G27 G20 G64 P0.001.
Radii are gone. Boards look respectable again.
If I might ask, what would possess anyone to make the corner cutting the default?
I could have discovered this problem with the mill and it might have been much more expensive than just producing an unusually ugly but electrically functional PC Board.
The following user(s) said Thank You: akb1212
- Thank you received: 2175
13 Apr 2020 16:57 #163886
Replied by cmorley on topic unwanted radiusing in LinuxCNC 2.8
IIRC the problem with G64 default comes with the fact that metric vrs imperial machine require very different defaults. i agree the current situation is not very good and has got alot of people.
Time to create page: 0.083 seconds
