X and Y movement when sitting still?
  • Catch22
  • Catch22's Avatar Topic Author
  • Elite Member
  • Elite Member
19 Apr 2020 22:32 #164679 by Catch22
X and Y movement when sitting still? was created by Catch22
Just wondering if there is any way to get rid of the .0004 movement on x and y axis. I know the linear scales resolution is .0004 and that's how much it's moving back and forth. Is there anyway to stop this other than putting encoders on each motor?
19 Apr 2020 22:41 #164681 by PCW
Replied by PCW on topic X and Y movement when sitting still?
You can add some deadzone to the PID tuning though this is always a bit of a compromise
  • Catch22
  • Elite Member
  • Elite Member
19 Apr 2020 22:45 #164683 by Catch22
Replied by Catch22 on topic X and Y movement when sitting still?
Ok what is the compromise, not as accurate?
20 Apr 2020 14:18 - 20 Apr 2020 14:19 #164861 by PCW
Yes you will lose the deadzone setting worth of position resolution
Note that if you have a rapid dither, you can often reduce this substantially by adjusting
the drives zero (you can also do this in LinuxCNC by adjusting the "BIAS" in the calibrate menu)
Last edit: 20 Apr 2020 14:19 by PCW.
The following user(s) said Thank You: Catch22
Time to create page: 0.075 seconds
