latency Test
20 Apr 2020 13:07 #164850 by taloot
latency Test was created by taloot
i m having 2 usec latency on latency test and 500 000 on base-thread.tmax
which one is correct, im using latest 2.9
  • Moderator
  • Moderator
20 Apr 2020 13:44 #164855 by tommylight
Replied by tommylight on topic latency Test
Screenshots of latency test and latency-histogram, please.
21 Apr 2020 00:15 #164905 by taloot
Replied by taloot on topic latency Test
21 Apr 2020 02:32 #164915 by PCW
Replied by PCW on topic latency Test
Both are correct, the jitter is the scheduling latency
The base thread tmax is the maximum number of CPU cycles
that it takes to execute the entire base thread
The following user(s) said Thank You: taloot
Time to create page: 0.134 seconds
