Controlling three phase motors
- Agathon
21 Apr 2020 17:21 #164983
by Agathon
Controlling three phase motors was created by Agathon
I think I know the answer to this question, but I'd be interested in the communities thoughts.
I am in the process of updating a 1980 Fehlmann mill-drill my plan is to use LinuxCNC with a Mesa control card. This video from a couple of years ago more or less shows where I am with the machine:
I've been busy with other projects and am now returning to the Fehlmann.
I now have the stops set up on the control of the milling head and find that repeatability to the micro-switches is not great at 0.1mm.
The vertical travel is effected by a special 0.21kW 660rpm three phase induction motor built-in to the head.
Later machines such as the Picomax 54 and 55 seem to have precision cnc control over the vertical position of the head as can be clearly seen here:
I suspect this is achieved by replacing the induction motor with a servo and a glass or magnetic scale to give the absolute vertical postion.
Finally, my question: I am just seeking confirmation that even with the addition of a dro scale it would not be possible to achieve control over the absolute postion of the vertical head using the current three phase induction motor.
Given a negative answer, then I guess that if I replace the induction motor with a suitable servo motor - maybe even a stepper given the low speed - along with a dro scale that it should be possible to have control over the absolute vertical position of the head.
Whether it is possible to integrate this into LCNC would be my next quetion!!
Thanks for your patience!
David
David
- Thank you received: 7468
21 Apr 2020 17:42 #164985
Replied by tommylight on topic Controlling three phase motors
It would be possible to use the existing motor with a new 3 phase servo drive, granted you have the possibilty to add an encoder to the motor or a linear scale to the axis, but the tuning of that drive to that motor might prove daunting. Much better choice would be to get a new set of motor and drive, but beware that most of the cheap chinese ones are not tuned, lending itself to the above mentioned issue.
Linuxcnc can control servo drives with encoders and linear scales, even both on the same axis.
Stepper would be a simpler choice, for sure.
- Agathon
21 Apr 2020 19:17 #164996
by Agathon
Replied by Agathon on topic Controlling three phase motors
Thanks Tommy, I have to admit that I was ignorant about using a servo drive on a conventional squirel-cage induction motor.
Can you point me to somewhere where I can read about controlling two axes in the same plane?
21 Apr 2020 20:39 #165003
But you can use a VFD for an induction motor, i just do not know if it would be good for use as an axis since i never tested that.
That will not work, sorry i missed it if it was mentioned.Thanks Tommy, I have to admit that I was ignorant about using a servo drive on a conventional squirel-cage induction motor.
- Agathon
21 Apr 2020 20:46 #165006
by Agathon
That's OK, I think I probably wasn't clear enough in my initial description. It looks like using a stepper would be the simplest thing.
If you know of any threads on controlling and integrating two motors on the same axis let me know.
21 Apr 2020 21:16 #165010
To get a glimpse on how that looks in hal and ini, there should be some sims included with Linuxcnc in /sim/axis/extrajoints from the Linuxcnc menu.
Since version 2.8 of Linuxcnc, any axis can have as many motors as you need ( do not know the limit ).If you know of any threads on controlling and integrating two motors on the same axis let me know.
The following user(s) said Thank You: Agathon
- Mike_Eitel
- Thank you received: 183
22 Apr 2020 06:59 #165051
by Mike_Eitel
Replied by Mike_Eitel on topic Controlling three phase motors
Just for my curiosity:
Would this be an application in witch i would use W as second vertical axis to adjust both 'Z'-axis independent by gcode? (could be a nice idea for my old FM4)
Mike
Mike
- Agathon
22 Apr 2020 09:40 #165062
by Agathon
Hi Mike, Fehlmann certainly refer to the "coarse" vertical positioning of the milling head as the W axis.
Out of curiosity what is an FM4?
David
David
- Mike_Eitel
22 Apr 2020 10:02 #165066
by Mike_Eitel
FM4 is an old Stadelmann mill. Similar to todays BM4
Nothing special but good enough for an old "electronics" engineer.
Mike
Mike
- Agathon
22 Apr 2020 10:17 #165069
by Agathon
Ah right, I found your website Mike. Looks like you're in Switzerland.
Yes, your little mill drill has the same issue as I have with the Fehlmann. How do you control the quill Z axis - I'm guessing with a ball screw? Mine uses the quill rack which has an astonishingly small amount of backlash. The return springs also act on the quill itself rather than the pinion which means the tiny amount of backlash shouln't be a problem except with very large cuts.
If you decide to add a W axis to your coarse positioning I'd be interest to see how you go about it and how it integrates into the CNC control.
David
David
Time to create page: 0.093 seconds
