proma sd step/dir
  • getyers
  • getyers's Avatar Topic Author
  • New Member
  • New Member
30 Apr 2020 20:36 #166251 by getyers
proma sd step/dir was created by getyers
what gui for the use of PROMA SD STEP/DIR
  • Moderator
  • Moderator
30 Apr 2020 20:46 #166254 by tommylight
Replied by tommylight on topic proma sd step/dir
Any of the normal Axis or Gmoccapy will do just fine, but you might want to use PlasmaC as it has other features included, like material thickness and based on that it will adjust the cut feed rate, and probing if you have a floating head on the Z axis.
30 Apr 2020 21:07 #166257 by rodw
Replied by rodw on topic proma sd step/dir
I've got a feeling that to use plasmac will take a fair bit of hacking to unhook all of the THC stuff, so I think I'd build a simple working config in axis first. If the SD does not probe by itself, use a simple touch off routine in gcode will be the trick
Time to create page: 0.073 seconds
