7i77 not detecting all of a sudden
07 May 2020 01:09 - 07 May 2020 01:09 #166917 by PCW
Replied by PCW on topic 7i77 not detecting all of a sudden
Where are you located?sounds like both the 7I77 and 5I25 should returned for evaluation
Since you lost both serial interfaces at the same time it does sound like a 5I25 problem.
If you happen to have the right cable, a quick test would be to try the other 5I25 port (P2)
Last edit: 07 May 2020 01:09 by PCW.
  • SPH
  • SPH's Avatar Topic Author
  • Premium Member
  • Premium Member
07 May 2020 01:38 #166919 by SPH
Replied by SPH on topic 7i77 not detecting all of a sudden
Mmm, I was afraid that might be the case. In Australia unfortunately so it's not going to be a quick turn around. Cant be helped though.
It's not great effort to make a DB25/dsub adapter or complete cable. I'll grab some 25pin ribbon cable and a few punch plugs when I'm out.
  • SPH
  • Premium Member
  • Premium Member
07 May 2020 01:44 #166921 by SPH
Oh and I'll post up my wiring diagram/pictures of the setup too. I'm not ruling out some dumb mistake in my wiring that's damaged something.
I'd still like to test another PC but it might take a while to pick one up. I grabbed a couple off a friend but one wouldn't boot with the 5i25 installed and the other didn't have a PCI slot, just PCIe. Duh. PCI slots are starting to phase out it seems.
The following user(s) said Thank You: PMCD
Time to create page: 0.218 seconds
