VELOCITY AXIS RETURN WITH HOME_OFFSET VALUE
- papagno-source
- Thank you received: 13
10 May 2020 11:45 #167254
by papagno-source
VELOCITY AXIS RETURN WITH HOME_OFFSET VALUE was created by papagno-source
Hi when impose a value in HOME_OFFSET , the joint after found the zero signal encoder , move im Rapid velocity at value the HOME_OFFSET.
Can reduce this return velocity movement , in same case is good not move in rapid in reference sequence operation.
How can modification in code part this ?
thanks
thanks
- Thank you received: 7468
10 May 2020 11:47 #167255
Replied by tommylight on topic VELOCITY AXIS RETURN WITH HOME_OFFSET VALUE
In the ini file for that axis:
HOME_FINAL_VELOCITY = 5 or 10 or 100
whatever suits your needs.
Time to create page: 0.079 seconds
