G54 problem with new installation
- Pro_El
- Thank you received: 3
12 May 2020 04:10 #167458
by Pro_El
G54 problem with new installation was created by Pro_El
Hello
I made new installation of LCNC 2.7.15 with Stretch and 7i77 mesa board and i have couple of problems. First problem is G54 position. Everything is working but only two times when i power off the machine and turn on did not remember G54. Other times it remember OK. Power cycle i made is first shutting down LCNC and then PC and in the end i turn off the power. If storing G54 is not consistent should i write down G54 coordinates ??
Mu second problem is with input i put with Pncconf. Every input work like it should but only Cycle start and Abort doing nothing. Did not executes program or abort program. I see the signal came in Hal Configuration signal window so wiring is ok only LCNC not take aktions for this inputs.
- Thank you received: 2175
12 May 2020 04:48 #167460
Replied by cmorley on topic G54 problem with new installation
Cycle start and abort are configured for the Touchy screen, but looking at the code it doesn't get configured for any other.
Do you home the machine?
adding these two line to your custom_postgui.hal file:
net cycle-start halui.program.run
net abort halui.program.stop
Should make them work.
The following user(s) said Thank You: Pro_El
- Pro_El
12 May 2020 04:54 #167461
by Pro_El
Replied by Pro_El on topic G54 problem with new installation
Yes I home the machine first. Thanks for the information i will try enter this two lines and reported latter.
12 May 2020 05:04 #167463
how wrong is G54 when it is inconsistent?
- Pro_El
12 May 2020 05:16 #167465
by Pro_El
G54 It cames to zero.it did not remember after power off. but it happens once in 10 times not to remember and g54 came to zero. Same like i never make touch off. When it remember G54 it is very accurate.
- bbsr_5a
- Thank you received: 106
12 May 2020 06:41 #167468
by bbsr_5a
Replied by bbsr_5a on topic G54 problem with new installation
you also need to delete the var.bak file (if it is there in the machine file folder)
on my plasma i got the same problem and after i deleted that file it wars gone for some long time
- Thank you received: 4144
12 May 2020 07:34 #167474
Replied by rodw on topic G54 problem with new installation
I think plasmac calls that file by a different name. but yes when setting up a machine it can get stuffed up so deleting it is the solution but now I finished setting up my machine I've never had to deleted it for several years. ANd yes LCNC saves its values in that file.
- Pro_El
12 May 2020 09:28 #167491
by Pro_El
Thanks i will try to delete and see if that solve the issue.
- Pro_El
30 May 2020 17:58 #169439
by Pro_El
Sorry for late respond just to confirm that:
Delete var.bak file fix the problem with remember G54.. Offsets
And this two lines in postgui Hal file makes this input pins to work.
- Pro_El
30 May 2020 18:05 #169440
by Pro_El
I have one weird problem with G54. When i start the LCNC and i execute in MDI G55 and hit back G54 it show on DRO First G55 than give back G54. But when i run one program and If i hit in MDI G55 And than G54 didnt show G54 stay in G55 DRO. I dont now how to fix this problem.
Time to create page: 0.342 seconds
