Last co-ordinate return
- theo
15 May 2020 17:49 #167884
by theo
Last co-ordinate return was created by theo
Good day all. I was wondering if there is a g-code that returns a router to the last location.
When I probe my Z hight for tool 1, I need to regenter the location of the prone for every tool I change. Is there a way to program linuxcnc to return to the last position when doing a tool change
- bbsr_5a
- Thank you received: 106
16 May 2020 06:27 #167921
by bbsr_5a
Replied by bbsr_5a on topic Last co-ordinate return
Hi
the Toolchange is done by G30 Position on behave of Machine Coordinate system G53
it then changes back to the System you are on G54-G59.9
and as you init a toolchange the CAM knows where you have been so the CAN shoudt do the JOB
but you want to do it manuell as i read correct
you can store the position LAST by Mcode in a VAR and return after toolchange by another Mcode
look into PLASMAC there is a Return to last Pos
- theo
16 May 2020 07:55 #167926
by theo
Replied by theo on topic Last co-ordinate return
Hi. I recently recon my router. It is a Ruijie machine from China. If I remember correctly. After every tool change whether it is in a program or manual. The machine would return to the last co-ordinate and the it would go to the tight co-ordinate and carry on with the job.
I'm looking to do the same in linuxcnc
