Forum colours, or is there any possibility of changing them to something darker
  • tommylight's Avatar Topic Author
  • Online
  • Moderator
  • Moderator
24 May 2020 23:41 #168839 by tommylight
Several times in the last few years i wanted to raise this question as it is quite straining on the eyes, but since no one else was complaining i just moved on.
So, what are the chances of changing that to something darker ?
JT, help ! :)
As an idea, i use often :
ethermine.org/miners/2eaacfc216f91a00303...786098340a/dashboard
That seems very calming when looking at it, and you can see how much ethereum/$ i have there.
25 May 2020 05:10 #168843 by Aciera
With firefox you could use the "darkreader" add-on.
The following user(s) said Thank You: tommylight, Badger, jay1st
  • Online
  • Moderator
  • Moderator
25 May 2020 08:27 - 25 May 2020 08:28 #168849 by tommylight
This one works ! :)
Thank you.
A while back i have tried some of these add ons, they would all mess up the colours so it would leave white squares, non visible test, and some other hiccups. This one seems to work OK so far.
Last edit: 25 May 2020 08:28 by tommylight. Reason: attachment
  • Online
  • Moderator
  • Moderator
25 May 2020 21:35 #168910 by tommylight
Well this turned out to work nicely and after a day of use, i am pleased.
Again thank you for a nice find.
26 May 2020 12:28 #168973 by jay1st
Good idea, helps the eyes !
Time to create page: 0.142 seconds
