Cambam install?
- JayDeeTOL
25 May 2020 12:41 #168862
by JayDeeTOL
Cambam install? was created by JayDeeTOL
Hello everyone
I have everything up and running on the linuxcnc debain 2.7.15. Trying to install cambam and it dosen't show me anything from that linux debain version. Can anyone help me with that or link me to another program for generating g code?
Jason
Jason
- Thank you received: 7468
25 May 2020 13:07 #168865
Replied by tommylight on topic Cambam install?
You can use Inkscape for 2D/2.5D and plasma, Freecad for 3D, BlenderCAM for 3D and 5 axis i think, never used it properly so not sure, Also PyCAM works on Linux nicely, but it is slow to calculate paths.
- JayDeeTOL
25 May 2020 14:14 #168871
by JayDeeTOL
Replied by JayDeeTOL on topic Cambam install?
Thank you. I guess I need to learn how to install all of this. Very confusing.
- Reinhard
- Thank you received: 94
25 May 2020 16:08 #168876
by Reinhard
Replied by Reinhard on topic Cambam install?
Don't know, what does confuse you?
When you read cambams website , its nicely explained and it works out of the box.
well, at least for me on my linuxbox running debian ...
beyond that - cambam has a forum, where you can ask for help
cheers Reinhard
cheers Reinhard
- JayDeeTOL
25 May 2020 16:10 #168877
by JayDeeTOL
Stuck on the mono repository system.
- JayDeeTOL
25 May 2020 16:15 #168878
by JayDeeTOL
which debain to i try 9 or 10?
25 May 2020 16:43 #168880
In a terminal:
sudo apt install inkscape freecad
blendercam has to be downloaded from here:
drive.google.com/drive/folders/0B8_m8tGvVyKpYUVTMm14YWxTWEk
extract and double click on blender.
Might have to also install below, if you do not get the CAM screen at start.
sudo apt-get install libgeos-dev
sudo apt-get install python3-dev
- JayDeeTOL
25 May 2020 16:45 #168882
by JayDeeTOL
It's telling me first line input command not found.
25 May 2020 16:47 #168883
sudo apt-get install inkscape freecad
try this
try this
- JayDeeTOL
25 May 2020 16:50 #168884
by JayDeeTOL
Thank you so much. The last 2 line started to load int the terminal window.
freecad is telling me it has no installation candidate.
