Single-board or motherboard/CPU combo suggestion
- nicber
25 May 2020 20:41 #168904
by nicber
Single-board or motherboard/CPU combo suggestion was created by nicber
Good evening everybody,
I've pourchased a 7i76E. I've looked around but I haven't find anything, probably because I haven't looked in the right places. Could someone suggest a single-board or mb/CPU combo that it's known working flawlessly with LinuxCNC?
Thanks in advance.
Thanks in advance.
- Thank you received: 7468
25 May 2020 20:50 #168907
Replied by tommylight on topic Single-board or motherboard/CPU combo suggestion
Have a look here for some ideas
forum.linuxcnc.org/18-computer/38838-har...ts-used-pc-s?start=0
- nicber
25 May 2020 21:09 #168909
by nicber
Replied by nicber on topic Single-board or motherboard/CPU combo suggestion
Thank for the suggestion, I've looked at the thread, from what I've understood this, ASUS H61M-K, 4GB RAM, with RTAI was the best of the systems that you've tested.
I'm going to search one of these boards and a fullscreen touch display.
- nicber
28 May 2020 07:56 #169202
by nicber
Hi everybody,
After some more reading I found this for around 100€. Dell OPTIPLEX 7010 DT INTEL CORE I5-3470 8GB RAM. Is this good paired with a 7i76E?
I also would like to use QtPyVCP, does this hardware allow that?
Last question does someone have a suggestion for a fullscreen touch display?
Thank in advance for the patience going through all of my questions.
Have a nice day.
Have a nice day.
28 May 2020 09:13 #169206
But i never tested a 7010, so not sure.
That should be an Enterprise Dell PC, and all of those types of PC's worked perfectly with LinuxCNC so far, i did have a 9020 i think, it is running a router for several years now with a Mesa 7i6E without issues.After some more reading I found this for around 100€. Dell OPTIPLEX 7010 DT INTEL CORE I5-3470 8GB RAM. Is this good paired with a 7i76E?
- nicber
29 May 2020 07:06 #169280
by nicber
Thank for the reply.
I think that the one I found is one generation older than yours, but I hope that it would work fine. I've checked for the openGL specification to run probe basic and it should be fine.
Now I just need to find a touch screen monitor.
Probably in a week or so I'm starting to wire everything. Thanks for your support.
- bbsr_5a
- Thank you received: 106
29 May 2020 07:11 #169282
by bbsr_5a
Replied by bbsr_5a on topic Single-board or motherboard/CPU combo suggestion
bevor full wirer just check the setup by a simple relay or LED 2mA to be shure you got things PC to 7i76e set up correct and working
be shure to get a very good >8V powersupply for testing
- nicber
29 May 2020 07:15 #169283
by nicber
I have a Siemens 10A 24V industrial power supply, I hope it is good enough. I was thinking exactly that, before wiring everything up in the cabinet I'm going to wire a motor driver, some buttons and an mpg to do some testing as I'm new to LinuxCNC.
Thank for the advice.
Time to create page: 0.109 seconds
