i have following problem to intall python3-tk
29 May 2020 16:16 - 29 May 2020 16:17 #169323 by Marcodi
hi, i have a problem installing python3-tk. Some kind of repository location, but not a clue how to set another one. sources.list is empty and sources.list.d is empty too
master@cm /var/cache/apt/archives $ sudo apt-get install python3-tk
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
  libbonoboui2-0 libbonoboui2-common libgnomeui-0 libgnomeui-common
  python-gnome2
Use 'sudo apt autoremove' to remove them.
Suggested packages:
  tix python3-tk-dbg
The following NEW packages will be installed
  python3-tk
0 to upgrade, 1 to newly install, 0 to remove and 100 not to upgrade.
Need to get 25.1 kB of archives.
After this operation, 89.1 kB of additional disk space will be used.
Err:1 http://ftp.kfki.hu/linux/ubuntu xenial/main amd64 python3-tk amd64 3.5.1-1
  404  Not Found [IP: 148.6.0.24 80]
E: Failed to fetch http://ftp.kfki.hu/linux/ubuntu/pool/main/p/python3-stdlib-extensions/python3-tk_3.5.1-1_amd64.deb  404  Not Found [IP: 148.6.0.24 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
How do i get rid of this ftp.kfki.hu as a download location and change it to a common one. I am really at a loss. I am running Linux Mint
Last edit: 29 May 2020 16:17 by Marcodi.
  • Moderator
  • Moderator
29 May 2020 16:29 #169326 by tommylight
Replied by tommylight on topic i have following problem to intall python3-tk
Did you do a
sudo apt-get update
before trying to install it?
If yes, you can change the default repositories in the software sources, from the menu.
29 May 2020 16:58 #169327 by Marcodi
Replied by Marcodi on topic i have following problem to intall python3-tk
problem solved. Sorry for the question
