Setpoint Mcode
- lorisdag
31 May 2020 17:15 #169536
by lorisdag
Replied by lorisdag on topic Setpoint Mcode
hello nice solution tomorrow I try if it works thanks
- lorisdag
31 May 2020 17:23 #169537
by lorisdag
you're right but translating Italian into English is sometimes very difficult for me
- Thank you received: 7468
31 May 2020 17:33 #169538
Replied by tommylight on topic Setpoint Mcode
You can write in Italian and English here, there are some very knowledgable Italian members here, and i can understand Italian to some degree.you're right but translating Italian into English is sometimes very difficult for me
- lorisdag
06 Jun 2020 09:31 #170329
by lorisdag
Ciao scrivo in italiano ho fatto diverse prove e ho
Visto che bisogna dare due impulsi con lo switch
per avere l'azzeramento dell'asse perché con il primo si ferma con il secondo va a "0" chiedo se in qualche modo e possibile fare tutto in una volta grazie
06 Jun 2020 10:08 #170332
- lorisdag
06 Jun 2020 10:17 #170334
by lorisdag
Ciao io devo fare "0" in x o y con pezzo in movimento e passare a hal con uno switch laser
- lorisdag
06 Jun 2020 10:26 #170336
by lorisdag
Un esempoi è questo:
06 Jun 2020 10:50 #170340
That i do not know how to do, yet.
I am thinking of doing something like that for finding the material edge with a laser, but in my case it is very hard to discern between the material and a water table.
- Thank you received: 2164
06 Jun 2020 11:15 - 06 Jun 2020 11:19 #170344
Replied by Aciera on topic Setpoint Mcode
One problem is to create a pulse when the laser sensor detects the work piece as it will not change back to 0 before the piece is past. I know only how to do that in classicladder.
That leads to the next challenge of signal speed because the work piece is moving and the signal of the laser sensor will require some time to be fed through the electronics and software. So by the time the DRO is set to "0" the work piece is going to be already past the sensor by some distance. There is no avoiding this but with a real time system you might be able to figure out how much offset the system has depending on the speed of the work piece.
Measuring the length of the piece might actually be the easier task because it involves also the negative edge and the delay in the second edge would compensate for the delay in the first.
Last edit: 06 Jun 2020 11:19 by Aciera.
- lorisdag
06 Jun 2020 13:41 #170365
by lorisdag
Ciao ho risolto mettendo uno switch manuale per fare la seconda lettura e tutto funziona
