Mesa Ethernet only when WiFi disabled - why?
31 May 2020 19:15 #169549 by idea
Using linuxcnc from the debian 9 install.
I can connect to my 7i93 (MESA ethernet) controller when i disable Wi-Fi, and unable to startup linuxcnc when it is connected. The same behaviour occurs when using a laptop.
Does anyone know why this is happening and how I can make it so that both can be connected?
Thanks,
David
31 May 2020 19:33 #169556 by PCW
Did you setup the Ethernet as suggested in the hm2_eth manual page?
In general its best to use the 10.10.10.10 address for Mesa Ethernet cards
so they do not overlap with common NAT address ranges provided by your router
31 May 2020 19:50 #169561 by idea
Yes the network is subnet1 at 192.168.20.x and the board is 192.168.1.121
31 May 2020 19:51 #169562 by idea
It is not just with the WI-Fi disconnected from the network, for it to work the wireless interface needs to be disabled.
31 May 2020 19:51 #169563 by PCW
with WIFI enabled, what does
ip a
report?
31 May 2020 21:42 #169575 by idea
Wifi disconnected - linux cnc connects
david@localhost:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:25:90:5b:17:12 brd ff:ff:ff:ff:ff:ff
    inet 169.254.4.13/16 brd 169.254.255.255 scope link eth0:avahi
    inet6 fe80::225:90ff:fe5b:1712/64 scope link
3: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether 00:25:90:5b:17:13 brd ff:ff:ff:ff:ff:ff
4: eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether 00:25:90:5b:17:14 brd ff:ff:ff:ff:ff:ff
5: eth3: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether 00:25:90:5b:17:15 brd ff:ff:ff:ff:ff:ff
6: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether e8:de:27:1e:2b:5c brd ff:ff:ff:ff:ff:ff
wifi connected
6: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    inet 192.168.20.29/24 brd 192.168.20.255 scope global dynamic wlan0
       valid_lft 86390sec preferred_lft 86390sec
    inet6 fe80::d562:f436:a857:e9be/64 scope link
linux cnc error
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.15
Machine configuration directory is '/home/david/linuxcnc/configs/7i93'
Machine configuration file is '7i93.ini'
INIFILE=/home/david/linuxcnc/configs/7i93/7i93.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./7i93.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: ERROR: 192.168.1.121: Could not retrieve mac address
Running HAL shutdown script
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./7i93.hal:8: waitpid failed /usr/bin/rtapi_app hm2_eth
./7i93.hal:8: /usr/bin/rtapi_app exited without becoming ready
./7i93.hal:8: insmod for hm2_eth failed, returned -1
1726
Stopping realtime threads
Unloading hal components
31 May 2020 21:53 - 31 May 2020 21:53 #169576 by PCW
It looks like you have not setup eth0 with a static IP address.
This can be done either through the network manager or by editing
the etc/network/interfaces file as the hm2_eth manual page describes
Last edit: 31 May 2020 21:53 by PCW.
The following user(s) said Thank You: idea
01 Jun 2020 20:53 #169713 by idea
Yes this was the issue, even though I was using network manager to make setting changes that were not propogating through.
It needed editing text files and restarting the machine for them to take affect.
Thank you for the help
Time to create page: 0.168 seconds
