EtherCAT
6 years 5 months ago - 6 years 5 months ago #169550 by charly
EtherCAT was created by charly
Hello
I have a Optimum BF46 milling machine with the step motor CNC kit
I done 5 years ago a first installation of LinuxCNC and use two LPT port to run it
I try to do a new installation and replace the second lpt port by a Beckhoff EtherCAT coupler (EK1100) on a Debian 10 with Preempt-RT kernel and LinuxCNC 2.9
I has download, compile, install the master EtherCAT ( version 1.5.2 ) and run it
The EtherCAT link is alive add i can get the auto-config with : ethercat xml
<?xml version="1.0" ?> <EtherCATInfoList> <EtherCATInfo> <!-- Slave 0 --> <Vendor> <Id>2</Id> </Vendor> <Descriptions> <Devices> <Device> <Type ProductCode="#x044d2c52" RevisionNo="#x00110000">EK1101</Type> <Name><![CDATA[EK1101 EtherCAT-Koppler (2A E-Bus, ID-Switch)]]></Name> <Sm Enable="0" StartAddress="#x1000" ControlByte="#x0" DefaultSize="0" /> <TxPdo Sm="0" Fixed="1" Mandatory="1"> <Index>#x1a00</Index> <Name>ID</Name> <Entry> <Index>#x6000</Index> <SubIndex>1</SubIndex> <BitLen>16</BitLen> <Name>ID</Name> <DataType>UINT16</DataType> </Entry> </TxPdo> </Device> </Devices> </Descriptions> </EtherCATInfo> <EtherCATInfo> <!-- Slave 1 --> <Vendor> <Id>2</Id> </Vendor> <Descriptions> <Devices> <Device> <Type ProductCode="#x04b23052" RevisionNo="#x00100000">EL1202</Type> <Name><![CDATA[EL1202 2K. Fast Dig. Eingang 24V, 1�s]]></Name> <Sm Enable="1" StartAddress="#x1000" ControlByte="#x0" DefaultSize="1" /> <TxPdo Sm="0" Fixed="1" Mandatory="1"> <Index>#x1a00</Index> <Name>Channel 1</Name> <Entry> <Index>#x6000</Index> <SubIndex>1</SubIndex> <BitLen>1</BitLen> <Name>Input</Name> <DataType>BOOL</DataType> </Entry> </TxPdo> <TxPdo Sm="0" Fixed="1" Mandatory="1"> <Index>#x1a01</Index> <Name>Channel 2</Name> <Entry> <Index>#x6000</Index> <SubIndex>2</SubIndex> <BitLen>1</BitLen> <Name>Input</Name> <DataType>BOOL</DataType> </Entry> </TxPdo> </Device> </Devices> </Descriptions> </EtherCATInfo> <EtherCATInfo> <!-- Slave 2 --> <Vendor> <Id>2</Id> </Vendor> <Descriptions> <Devices> <Device> <Type ProductCode="#x089a3052" RevisionNo="#x00100000">EL2202</Type> <Name><![CDATA[EL2202 2K. Dig. Ausgang 24V, 0.5A]]></Name> <Sm Enable="9" StartAddress="#xf00" ControlByte="#x44" DefaultSize="0" /> <RxPdo Sm="0" Fixed="1" Mandatory="1"> <Index>#x1600</Index> <Name>Channel 1</Name> <Entry> <Index>#x7000</Index> <SubIndex>1</SubIndex> <BitLen>1</BitLen> <Name>Output</Name> <DataType>BOOL</DataType> </Entry> <Entry> <Index>#x7000</Index> <SubIndex>2</SubIndex> <BitLen>1</BitLen> <Name>TriState</Name> <DataType>BOOL</DataType> </Entry> </RxPdo> <RxPdo Sm="0" Fixed="1" Mandatory="1"> <Index>#x1601</Index> <Name>Channel 2</Name> <Entry> <Index>#x7010</Index> <SubIndex>1</SubIndex> <BitLen>1</BitLen> <Name>Output</Name> <DataType>BOOL</DataType> </Entry> <Entry> <Index>#x7010</Index> <SubIndex>2</SubIndex> <BitLen>1</BitLen> <Name>TriState</Name> <DataType>BOOL</DataType> </Entry> </RxPdo> </Device> </Devices> </Descriptions> </EtherCATInfo> </EtherCATInfoList>
When i had in my hal file le chargement du module EtharCAT : loadusr -W lcec_conf ./ethercat_config_n.xml
linuxcnc don't went start : lcec_conf no such file or directory
I thinking the module glue EtherCAT hal is not in the main linuxcnc but i don't know how add it
I found two repository : github.com/sittner/linuxcnc-ethercat and github.com/CalvinHsu1223/LinuxCNC-EtherCAT-HAL-Driver but noone explain how to add the module to linuxcnc
Somebody have an idee ?
Last edit: 6 years 5 months ago by charly.
6 years 5 months ago - 6 years 5 months ago #169650 by 0x2102
Replied by 0x2102 on topic EtherCAT
Is "lcec_conf" in your machine config directory? If not, you will need to copy it, from where you compiled it, to your machine directory.
I would recommend to go through this thread for more information around EtherCat.
forum.linuxcnc.org/24-hal-components/223...t-hal-driver?start=0
Last edit: 6 years 5 months ago by 0x2102.
Time to create page: 0.282 seconds
