Cutting corners on feed override.
- anfänger
- Thank you received: 256
01 Jun 2020 15:59 #169684
by anfänger
Cutting corners on feed override. was created by anfänger
- Thank you received: 7468
01 Jun 2020 18:31 #169695
Replied by tommylight on topic Cutting corners on feed override.
G64 Pn , where n is the amount of allowed off the exact path.
Ex: G64 P0.1 will allow for only 0.1mm or inch of tolerance from the exact path.
The following user(s) said Thank You: anfänger
- anfänger
01 Jun 2020 19:53 #169705
by anfänger
Replied by anfänger on topic Cutting corners on feed override.
Thanks I'll have a look at it. and it seems I need to take a look at my post processor
