Can not get step settings that works OK
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 Jun 2020 13:12 #170509 by tecno
I have now been trying to get my numbers right for scale in INI
Trying with the help of pncconf but all I get is a rocket launcher ;)
I have DM542A drivers images-na.ssl-images-amazon.com/images/I...dhyL._AC_SL1500_.jpg
25mm pitch leadscrews on X and Y
10mm pitch leadscrew on Z
Here my settings
File Name: plasma.hal
File Size:5 KB
File Name: plasma.ini
File Size:3 KB
Can somebody have a look at this so I can get adequate speed for my plasma.
Cheers
Bengt
  • tecno
  • Platinum Member
  • Platinum Member
07 Jun 2020 14:18 #170516 by tecno
Replied by tecno on topic Can not get step settings that works OK
There must be some errors in pncconf with scale calc.
Manual calc
4000steps 25mmpitch = Scale 160
4000steps 10mm pitch = 400
So now that works.
AXIS reports velocity of 6000 that seems a bit slow, how do I get higher speeds? What needs to be edited?
07 Jun 2020 14:34 - 07 Jun 2020 14:35 #170519 by tommylight
Replied by tommylight on topic Can not get step settings that works OK
In the ini file:
Display section, max velocity
Traj section, max velocity
For each axis and joint, max velocity.
Set it for each axis to what they need to be, for the traj and display section, add another 20 to 30% so when moving both axis at the same time it does not clip the velocity of each axis.
Last edit: 07 Jun 2020 14:35 by tommylight. Reason: typo
The following user(s) said Thank You: tecno, bbsr_5a
  • tecno
  • Platinum Member
  • Platinum Member
07 Jun 2020 14:45 #170522 by tecno
[DISPLAY]
DISPLAY = axis
#DISPLAY = gmoccapy
POSITION_OFFSET = MACHINE
POSITION_FEEDBACK = COMMANDED
MAX_FEED_OVERRIDE = 1.2
CYCLE_TIME = 0.1
INTRO_TIME = 0
OPEN_FILE = ""
Nothing there on velocity!
07 Jun 2020 14:48 #170523 by tommylight
That is OK, no worries, it does work without it.
As an example here is one of my ini files display section:
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 50.000000
MAX_LINEAR_VELOCITY = 800
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
08 Jun 2020 01:39 #170584 by bbsr_5a
Replied by bbsr_5a on topic Can not get step settings that works OK
MAX_VELOCITY = 220.0
MAX_ACCELERATION = 1200.0
is a very good value to get the DM542T to speed
the Z on a plasma shout be
MAX_VELOCITY = 80.0
MAX_ACCELERATION = 800.0
  • tecno
  • Platinum Member
  • Platinum Member
08 Jun 2020 04:04 #170596 by tecno
Now I get following errors on all JOINTS
File Name: plasma_2020-06-08.ini
File Size:3 KB
File Name: plasma_2020-06-08.hal
File Size:5 KB
Is the RPi4 up to this task?
08 Jun 2020 04:30 #170601 by bbsr_5a
REDUCE the ACC
MAX_ACCELERATION = 750.0
get down till you get no following then step up again
the DM542T is a Magic box
why dident you choose the DM556 REAL digital it can speed up 25times then the 542Original H
08 Jun 2020 04:46 #170603 by tommylight
In joint sections:
stepgen stuff must be 25 to 50% more than max velocity and acceleration.
  • tecno
  • Platinum Member
  • Platinum Member
08 Jun 2020 05:26 #170614 by tecno
Even with following I still get following error on JOINT0
[AXIS_X]
MIN_LIMIT = -495
MAX_LIMIT = 0
MAX_VELOCITY = 100
MAX_ACCELERATION = 300
[AXIS_Y]
MIN_LIMIT = 0
MAX_LIMIT = -495
MAX_VELOCITY = 200
[AXIS_Z]
MIN_LIMIT = 0
MAX_LIMIT = -100
MAX_VELOCITY = 80
[JOINT_0]
AXIS = X
MIN_LIMIT = -5000
MAX_LIMIT = 5000
MAX_VELOCITY = 100
SCALE = -400
STEPGEN_MAX_VEL = 150
STEPGEN_MAX_ACC = 450
FERROR = 0.0051
MIN_FERROR = 0.0025
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
DEADBAND = 0
P = 1000
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0.00013
BIAS = 0
MAX_OUTPUT = 0
MAX_ERROR = 0.0127
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
Time to create page: 0.108 seconds
