HAL Component Help
08 Jun 2020 22:55 #170721 by cmorley
Replied by cmorley on topic HAL Component Help
here is a fairly minimum component to show extra functions.
Though it seems you can't reference HAL pins in the functions
component test1;
pin in s32 in;
pin out bit out1;
pin out bit out2;
function _;
license "GPL";
// private functions
int set(void){
    return 1;
int unset(void){
    return 0;
//main function
FUNCTION(_) {
    if (in ==1){
        out1 = set();
        out2 = unset();
    if (in ==2){
        out1 = unset();
        out2 = set();
09 Jun 2020 06:38 #170761 by cmorley
Similar that passes HAL bit pin reference to the function:
component test1;
pin in s32 in;
pin out bit out1;
pin out bit out2;
function _;
license "GPL";
// general pin setting function
void set(hal_bit_t *p){
    *p = 1;
// general pin unsetting function
void unset(hal_bit_t *p){
    *p = 0;
//main function
FUNCTION(_) {
    if (in < 0){
        set(&out1);
        unset(&out2);
    }else if (in >0){
        unset(&out2);
        set(&out2);
    }else{
        unset(&out1);
        unset(&out2);
I'm hoping this helps you ...
The following user(s) said Thank You: Bend
09 Jun 2020 07:15 #170771 by rodw
Replied by rodw on topic HAL Component Help
Thats a handy idea Chris!
09 Jun 2020 13:46 - 09 Jun 2020 13:50 #170834 by Bend
Replied by Bend on topic HAL Component Help
That's a pretty slick idea, i will give that a try. Thanks.
Last edit: 09 Jun 2020 13:50 by Bend.
09 Jun 2020 13:50 #170835 by bbsr_5a
Replied by bbsr_5a on topic HAL Component Help
why arend simple pinsets even in HAL done by UserMcodes
then yoiu can use things in G-code to do
simple pinsettings shoudent be done in a comp
09 Jun 2020 14:19 #170837 by Bend
In our specific case, the comp handles all of the tool change process. As such it is simpler to contain all the pin-out in the component for the tool changer.
Time to create page: 0.177 seconds
