- LinuxCNC
- General LinuxCNC Questions
- getting error messages when updating to linuxcnc 2.9 and 7i96 issues
- Aldenflorio
- Thank you received: 15
08 Jun 2020 19:44 #170673
by Aldenflorio
getting error messages when updating to linuxcnc 2.9 and 7i96 issues was created by Aldenflorio
I’m trying to update to 2.9 from 2.7. I’ve followed the updating videos and the forums instructions. When I open linuxcnc I get the error message attached. I’ve don’t the python command and just tried the python3 command and still get the same message.
- Aldenflorio
08 Jun 2020 19:50 - 08 Jun 2020 19:52 #170674
by Aldenflorio
Replied by Aldenflorio on topic getting error messages when updating to linuxcnc 2.9 and 7i96 issues
Last edit: 08 Jun 2020 19:52 by Aldenflorio.
- Thank you received: 2175
08 Jun 2020 19:51 #170675
Replied by cmorley on topic getting error messages when updating to linuxcnc 2.9 and 7i96 issues
That is not a linuxcnc error message.
Please post the linuxcnc error message that caused you to try to update python-tk
- Aldenflorio
08 Jun 2020 19:53 #170676
by Aldenflorio
Just did. It was apparently too large of a file and I didn’t know at first so it’s up now
08 Jun 2020 19:57 #170678
Is there a good reason to use 2.9 (aka master) instead of 2.8?
master is being converted to use python3 etc so will be somewhat unstable.
Your error message seems common though I haven't seen the solution yet.
Can you describe the distro version you are using and possibly link to the forum post you used (there are several)
Chris
Chris
- Aldenflorio
08 Jun 2020 20:01 #170680
by Aldenflorio
It’s up
- Aldenflorio
08 Jun 2020 20:09 #170681
by Aldenflorio
I dont believe so. I’m using the Mesa 7i96 board with a ethernet connection though and I think I remember hearing that the newer versions accept Ethernet. Not sure if that’s both 2.8 and 2.9 or just 2.9.
I’m not sure exactly how do do as you asked, but I’m using Debian gnu/linux live (kernel 4.9.0-8-rt-amd64) if that helps. I’ve followed this video along with this thread
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
- Thank you received: 7468
08 Jun 2020 20:13 #170682
Replied by tommylight on topic getting error messages when updating to linuxcnc 2.9 and 7i96 issues
This issue is due to the updater not working with the available version of python-tk.
Several attempts by installing anything with python and tk failed.
Linuxcnc is not affected by it, just the updater for the older versions of config file. Editing files manually works always.
- Aldenflorio
08 Jun 2020 20:18 #170684
by Aldenflorio
So then what do I need to do?
08 Jun 2020 20:23 #170686
Editing hal and ini files manually works always.
- LinuxCNC
Time to create page: 0.138 seconds
