Moving motors with the directional keys doesn’t work for me
  • Aldenflorio
  • Aldenflorio's Avatar Topic Author
  • Platinum Member
  • Platinum Member
12 Jun 2020 05:27 - 12 Jun 2020 05:27 #171214 by Aldenflorio
I want to be able to actually move the motors using the arrow directional keys on the key board. But when in Linux CNC and upon pressed a direction a path line showed up but no motors move. I already configured and tested the motors so they work
Last edit: 12 Jun 2020 05:27 by Aldenflorio.
12 Jun 2020 07:52 #171219 by bbsr_5a
that is inposible you tell
is the slighter in AXIS set to 100%
is the speed genral set to somthing not 0 and not max
did you load the right Machine not a SIM
  • Moderator
  • Moderator
12 Jun 2020 09:49 #171235 by tommylight
  • Aldenflorio
  • Platinum Member
  • Platinum Member
12 Jun 2020 15:44 #171271 by Aldenflorio
I’m not sure how to add lines to the Hal files. And I tried looking for the presets button and could find it.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
12 Jun 2020 15:49 - 12 Jun 2020 16:00 #171272 by Aldenflorio
Yeah I loaded the right machine I believe. all the things you listed are set. When configuring the motors and testing them there they move. And as in move I mean with the program. At no point can I move the motors with my hands
Last edit: 12 Jun 2020 16:00 by Aldenflorio.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
12 Jun 2020 16:02 - 12 Jun 2020 16:11 #171273 by Aldenflorio
-_- I figured it out. But I do have another question now. So like I said I’m using two motors for the y axis. When I move the motors using the arrow keys and stimulate the y axis only one motor moves. Why is that?
Last edit: 12 Jun 2020 16:11 by Aldenflorio.
12 Jun 2020 16:23 #171276 by Clive S
slaved motors have to be homed by putting HOME_ SEQUENCE= - some number ie -1 and the both have to be the same number note the minus sign. This make the motors in sync.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
12 Jun 2020 16:41 #171278 by Aldenflorio
Where do I do that. Is this how I set them up in the pncconf wizard?
Time to create page: 0.134 seconds
